UI Suggestion- Trunks Status
Discussion in '3CX Phone System - General' started by dig1234, Dec 9, 2015.
  1. dig1234
    Jun 1, 2015
    75
    Under System Status>Port/Trunks
    Trunks which do not require registration are listed as green "Registered (idle)" even though they are not actually registered because no registration is necessary. This can cause confusion. Example that happened to us where the trunk was not functioning for any reason it still shows green "Registered (idle). Which is a false positive of functionality. Perhaps it can be listed simply as grey Idle or similar.
  2. nikosT_3cx
    3CX Support
    Jun 2, 2014
    57
    please note that for now this can not be changed. I would recommend to upload a request on our website where the Developers check for requests on the behavior of the Phone System. You may find the like here : http://www.3cx.com/forums/3cx-ideas-f57.html
  3. dig1234
    Jun 1, 2015
    75
    Re-posted here: http://www.3cx.com/forums/confusing-status-for-ip-based-runks-non-registering-43591.html
    Thanks!
