UK Caller ID - Suitable Gateway
Discussion in '3CX Phone System - General' started by abercoms, Jun 11, 2007.
  1. abercoms
    May 3, 2007
    19
    Can anyone advise a suitable gateway that will do UK Caller ID from PSTN via Digital Receptionist, reading through some posts, I am confused (not hard at the moment) saying DR doesnt pass through. Just for the sake of testing I tried an (unsuported) SPA400 coz I've got one on the config supplied here, yep it works but just like on the SPA9000 I get no caller ID...
    Thanks in advance
    Dave
  2. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    I would advise you ask your telco what CID standard is being used on your line. Most parts of europe are using ETSI FSK, the US is mainly Bellcore FSK. If I am not mistaken BT (U.K) have a propriety FSK standard. If you buy a gateway that does ESTI and Bellcore you still might have problems so it's best if you check first.
  3. abercoms
    May 3, 2007
    19
    Have you ever tried getting anything technical out of BT?
    I had hoped someone would say 'Yes, the such and such gateway works'
    I am aware of your approved list hopefully you will know of one which does from the list?
    Dave
