UK Date Format
Discussion in 'Ideas' started by akal, Oct 20, 2016.
UK Date Format 5 5 1votes
5/5, 1 vote
  1. akal
    Mar 27, 2009
    Hi Guys
    Would it be possible for you to implement being able to select a date format for 3CX Management Console. At present when we view our logs all the dates are in US date format, but we are a UK based company and would appreceiate being able to view our dates in the correct format.
    Many Thanks
    Darren
  2. Cjay
    Cjay New Member
    Feb 24, 2007
    199
    Where in particular are you seeing US date format? My activity/event logs & call reports are all in UK format. Could it be a Windows system setting that needs adjusting?
  3. max1
    May 16, 2014
    21
    I have this problem too on machines running Windows 10 and Debian. The date format for the machine is correct but the Console dates are not. Any ideas?
