UK Phone provider dialling codes
Discussion in '3CX Phone System - General' started by oliverm, Aug 3, 2011.
  1. oliverm
    Mar 10, 2009
    79
    Does anyone know where I can get a list of UK phone provider dialling codes? That is, I have a list of tariffs from our SIP provider (O2 = x.xp, Voda = x.yp etc). It doesnt tell me however which dialling codes they consider to be for O2, Voda etc.
    However I need to tell 3cx what dialling code is used for O2 calls, which for Voda, T-mobile etc.
    Does anyone know where I can get this list?
    Olly
    10,375
    231
    Ofcom has all of the prefix assignments available for download...http://www.ofcom.org.uk/static/numbering/index.htm
    Don't forget that with number potability, you can no longer assume that a particular prefix is linked to a particular provider. If you take your T-Mobile number to O2 and someone calls you, they now pay the rate to call an O2 user.
  3. oliverm
    Mar 10, 2009
    79
    Yeah, that occurred to me as i posted the question :)
    I'll just average out the costs.
    Olly
