UK Ringing Tone/Cadence
Discussion in '3CX Phone System - General' started by mesh, Oct 6, 2011.
  1. mesh
    Oct 6, 2011
    Hello guys,
    I'm looking for help changing the ringing tone/cadence on the 3CX phone system to a UK based one as are UK based.
    I know the cadence and the format I need to put into the system but I have no idea where to put it. Anyone done this before?
    11,105
    329
    It depends on what tones you are referring to. If the tone is one supplied by a SIP device, then the setting is in the device.
  3. mesh
    Oct 6, 2011
    I'm refering to the tone a caller hears when they ring into the 3CX system. I get an American style cadence no matter what rules I have set (deliver to extension, deliver to digital receptionist etc). So I am assuming it is not supplied by a SIP device but rather the 3CX system?
    Example.
    08000 365 247 is set to ring ext 801 which is a digital receptionist who answers with a "Welcome to.."
    So when I ring from off net (mobile phone) I get <american ring> <american ring> "Welcome to"...
    I guess its got to be set somewhere internally on 3CX?
  4. leejor
    11,105
    329
    I would have thought that when the UK prompt set was chosen, then the UK type ring-back (or engaged) tone would also be selected. I had a quick search for .wav files (which is the format I would suspect it to be in) on my PC running 3CX but nothing obvious stood out as a possible ring-back tone (without listening to all of them). Perhaps this was something overlooked or there is another more involved way of changing it. I know that when I have been in the UK and phoned various companies, it has not been uncommon to receive a North American ring-back tone while being transferred, so it may not be that unexpected by your callers.
    I can understand the desire to change it but how to do that may require an answer from someone at 3CX.
  5. mesh
    Oct 6, 2011
    Thanks for the reply. Where is this setting you mention? I don't recall seeing anything like that
  6. mesh
    Oct 6, 2011
    Found the prompt set, still American ring tone :(
