UltiDevCassinWebServer2a.exe get Windows Platform FIPS...
Discussion in '3CX Phone System - General' started by cmindus, Mar 18, 2010.
  1. cmindus
    Mar 4, 2010
    On Win2003StdServer English, 3CX Phone System8, clean install:
    UltiDevCassinWebServer2a.exe get exception This implementation is not part of the Windows Platform FIPS validated cryptographic algorithms.
    Event code: 3005
    Event message: An unhandled exception has occurred.
    Event time: 2010-03-18 22:42:48
    Event time (UTC): 2010-03-18 21:42:48
    Event ID: a638fea388864caf90607f262b752ed5
    Event sequence: 26
    Event occurrence: 1
    Event detail code: 0
    Application information:
    Application domain: 6e55b32f-2-129134221020625000
    Trust level: Full
    Application Virtual Path: /
    Application Path: C:\Documents and Settings\All Users\Application Data\3CX\Data\Http\Interface\
    Machine name: ONE
    Process information:
    Process ID: 2808
    Process name: UltiDevCassinWebServer2a.exe
    Account name: NT AUTHORITY\SYSTEM
    Exception information:
    Exception type: InvalidOperationException
    Exception message: This implementation is not part of the Windows Platform FIPS validated cryptographic algorithms.
    Request information:
    Request URL: http://localhost:5481/Route/1.92.4/ie/en-US/TcxTheme/Icons.logo.gif.wgx
    Request path: /Route/1.92.4/ie/en-US/TcxTheme/Icons.logo.gif.wgx
    User host address: 127.0.0.1
    User:
    Is authenticated: False
    Authentication Type:
    Thread account name: NT AUTHORITY\SYSTEM
    Thread information:
    Thread ID: 14
    Is impersonating: False
    Stack trace: at System.Security.Cryptography.RijndaelManaged..ctor()
    at System.Web.Configuration.MachineKeySection.ConfigureEncryptionObject()
    at System.Web.Configuration.MachineKeySection.EnsureConfig()
    at System.Web.Configuration.MachineKeySection.HashData(Byte[] buf, Byte[] modifier, Int32 start, Int32 length)
    at System.Web.Configuration.MachineKeySection.HashAndBase64EncodeString(String s)
    at System.Web.HttpCachePolicy.UpdateFromDependencies(HttpResponse response)
    at System.Web.HttpCachePolicy.UpdateCachedHeaders(HttpResponse response)
    at System.Web.HttpCachePolicy.GetCurrentSettings(HttpResponse response)
    at System.Web.Caching.OutputCacheModule.OnLeave(Object source, EventArgs eventArgs)
    at System.Web.HttpApplication.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
    at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
    Quick resolution:
    Edit registry key to remove FIPS complicancy checking in Windows, not very nice because it affects the entire server.
    Set HKLM\System\CurrentControlSet\Control\Lsa\FIPSAlgorithmPolicy to DWORD=0 instead of 1.
    Of course, with Group Policy turned on, this flag normally gets reset to "1" when the Active Directory is replicated.
    So here is another solution: better one: in the Cassini .config file (normally C:\Program Files\3CX PhoneSystem\Bin\Cassini\UltiDevCassinWebServer2a.exe.config), add the lines in italic-bold below in order to have the entire file look like below:
    <?xml version="1.0" encoding="utf-8" ?>
    <configuration>
    <appSettings>
    <add key="PingKeepRunningEverySoMinutes" value="5"/>
    </appSettings>
    <runtime>
    <enforceFIPSPolicy enabled="0"/>
    </runtime>
    </configuration>
  2. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    Actually we can't do much
    http://support.microsoft.com/kb/935434
