unable configuring office hours
Discussion in '3CX Phone System - General' started by MarcelvanKuilenburg, Mar 8, 2010.
  1. MarcelvanKuilenburg
    Nov 6, 2009
    29
    hello, using V8 suddenly it is impossible for me to configure office hours for the monday. I can fill them, add them but after apply the monday is empty again. other days is no problem. anyone any idea
    also the digital receptionist is not able to answer but only the standard voice
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Could you tell which build you are using, also do you only experience this with Monday?
    What are the exact steps you are taking?
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    I also was slightly confused, but the first line on that dialog is always empty at the time when you open it. That line provides you ability to set hours range for Monday-Friday at once.
    The Monday is second line :)
