Unable to accept forwarded calls
Discussion in '3CX Phone System - General' started by Wysepatrick, Nov 28, 2017.
  1. Wysepatrick
    Feb 3, 2016
    I recently switched to Level 3 SIP. Everything works fine except for when people try to forward calls to any of our DID's. Any call forwarded to us gets routed to the main trunk so its the main line every time. I have a couple of IVR's set up with DID's for an answering service for some remote locations that have landlines. I have noticed the "To: <sip:" is replaced with the forwarding party's id. Is there anything I can do to resolve this on my end?
    DIRECT CALL
    11/22/2017 10:53:31 AM - [CM500002]: Call(C:192): Info on incoming INVITE from Line:10000<<+1940xxxxxxx: Invite-IN Recv Req INVITE from x.x.120.45:5060 tid=04B809761fa44a348a4 Call-ID=1164184025_102704848@x.x.120.45: INVITE sip:+1972xxxxxxx@x.x.225.242:5060 SIP/2.0 Via: SIP/2.0/UDP x.x.120.45:5060;branch=z9hG4bK04B809761fa44a348a4 Max-Forwards: 70 Contact: "JOHN DOE " <sip:+1940xxxxxxx@x.x.120.45:5060>
    To: <sip:+1972xxxxxxx@x.x.225.242:5060>
    From: "JOHN DOE" <sip:+1940xxxxxxx@x.x.120.45:5060>;tag=gK04128c71 Call-ID: 1164184025_102704848@x.x.120.45 CSeq: 519739052 INVITE Accept: application/sdp, application/isup, application/dtmf, application/dtmf-relay, multipart/mixed Allow: INVITE, ACK, CANCEL, BYE, UPDATE Content-Disposition: session; handling=required Content-Type: application/sdp Recv-Info: x-broadworks-client-session-info Content-Length: 314
    FORWARDED CALL
    11/22/2017 9:54:28 AM - [CM500002]: Call(C:129): Info on incoming INVITE from Line:10000<<+1940xxxxxxx: Invite-IN Recv Req INVITE from x.x.120.45:5060 tid=0cBfc1c2a847952a245 Call-ID=1160525070_95144051@x.x.120.45: INVITE sip:+1972xxxxxxx@x.x.225.242:5060 SIP/2.0 Via: SIP/2.0/UDP x.x.120.45:5060;branch=z9hG4bK0cBfc1c2a847952a245 Max-Forwards: 70 Contact: "JOHN DOE" <sip:+1940x@x.x.120.45:5060>
    To: <sip:817xxxxxxx@x.x.225.242:5060>
    From: "JOHN DOE" <sip:+1940xxxxxxx@x.x.120.45:5060>;tag=gK0c71ef9f Call-ID: 1160525070_95144051@8.47.120.45 CSeq: 1858569162 INVITE Accept: application/sdp, application/isup, application/dtmf, application/dtmf-relay, multipart/mixed Allow: INVITE, ACK, CANCEL, BYE, UPDATE Content-Disposition: session; handling=required Content-Type: application/sdp Diversion: <sip:+1817xxxxxxx@x.x.120.45:5060>;privacy=off;screen=no; reason=unconditional; counter=1 Recv-Info: x-broadworks-client-session-info Content-Length: 314
    #1 Wysepatrick, Nov 28, 2017
    10,375
    231
    It sounds as if you may have to talk to your provider about this, but, they may not be able to do anything. They have to "deal with" , what is sent to them. It would appear that the DID number is not being passed along in the manner that you want to see (in a way you can use it to direct to a DID), possibly because the original caller did not dial the DID number.
    I have found it is not unusual, that when numbers get forwarded (on the PSTN network), unexpected consequences are the result.
