Unable to apply Update V11
Discussion in '3CX Phone System - General' started by leejor, Jun 2, 2014.
  1. leejor
    10,594
    255
    When attempting to apply the Version 11 heartbleed Update, I tick the box, click Download selected, get the notification that the a services need to be stopped, do you want to proceed..., click yes, and i get a small window lableled 3CX Interface. In it is a yellow triangle with an exclamation mark and the words...update.checker.filelocked.
    I've never come across this before. has anyone else ? thanks
    This is on a freshly installed Win 7 machine.
    3CX and the PC have been restarted a couple of times.
  2. bardissi
    bardissi Member
    Jan 31, 2012
    318
    No the only problem I had was with the fact we missed the "You must apply the .net update so that the services will start" message on that blog entry.
  3. roland.s
    3CX Support
    Mar 28, 2014
    75
    5
    Hi Bardissi,
    Are you using the standalone or Multi tenant? Also, which updated are you attempting to apply? please inform. I would also recommend to open a support ticket on the 3CX portal.
    Thank you.
  4. complex1
    complex1 Active Member
    Jan 25, 2010
    764
    39
    Hi leejor,
    Have you installed visual studio c++ 2008 sp1 redistributable before upgrading?
  5. leejor
    10,594
    255
    Not that I recall. After the initial Win 7 install, I only added what was requested to allow for the 3CX install. I won't have a chance until the weekend to try out your suggestion. Thanks
