Unable to assign Quick Dial Hotkey in MyPhone
Discussion in 'Windows' started by ashamesbury, Jan 23, 2013.
  1. ashamesbury
    Jan 4, 2013
    Good afternoon,
    I am using the MyPhone desktop client on my work PC.
    I would like to change the default hotkey that MyPhone uses to Quick Dial, but the option is greyed out.
    I have uninstalled and reinstalled the client and also made sure the Web Components pack is also installed, but this does not seem to have fixed the problem.
    I am using Windows 7 Pro and MyPhone 11.0.26364.600 client.
    Can you please advise if I have unticked something somewhere, so I can re-tick it and get it to work.?
    Many thanks,
    Ash.
