Unable to call outside number using Audicodes MP118
Discussion in '3CX Phone System - General' started by Reiner, Mar 20, 2009.
  1. Reiner
    Mar 20, 2009
    I am using having a problem using 3CX to make outside (external) call.
    Already follow up all instruction that came with manual and configuration guides but still having a problem
    Below is the equipment that we are using along with 3CX
    Gateway: Audicodes MP118
    SIP Phones: 2 unit x Linksys SPA942
    Had full 3CX License software
    I have try to monitor server activity log, below is the log
    16:33:47.701 [CM505002]: Gateway:[AudiocodesMP_118] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Audiocodes-Sip-Gateway-MP-118 FXS_FXO/v.5.20A.027.004] Transport: [sip:10.202.136.16:5060]
    16:33:47.701 [CM503002]: Call(10): Alerting sip:10004@10.202.136.31:5060
    16:33:47.581 [CM503004]: Call(10): Calling: PSTNline:0817770989@(Ln.10004@AudiocodesMP_118)@[Dev:sip:10004@10.202.136.31:5060, Dev:sip:10005@10.202.136.31:5060, Dev:sip:10006@10.202.136.31:5060, Dev:sip:10000@10.202.136.31:5060, Dev:sip:10001@10.202.136.31:5060, Dev:sip:10002@10.202.136.31:5060, Dev:sip:10003@10.202.136.31:5060]
    16:33:47.571 [CM503010]: Making route(s) to <sip:90817770989@10.202.136.16>
    16:33:47.571 [CM505001]: Ext.100: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-4.1.18] Transport: [sip:10.202.136.16:5060]
    16:33:47.561 [CM503001]: Call(10): Incoming call from Ext.100 to <sip:90817770989@10.202.136.16>
    I am using '9' as prefix in order to call outside in outbound rule
    Need all the help to solve the problem. Thanks
  2. manistopit
    Feb 18, 2009
    26
    do you still need help or all sorted
  3. leejor
    10,360
    226
    You need a few more logs, it sort of cuts off just as it's getting to the part with the failure message. (the good part)
