Unable to call through Salesforce
Discussion in '3CX Phone System - General' started by fahim, May 2, 2011.
  1. fahim
    Apr 13, 2011
    6
    I have integrated salesforce with 3CX PBX system successfully. I cannot make calls to Leads and Contacts mobile number it gives me an error message which is //Outbound call could not be processed: Destination is empty//
    but I can make calls to leads and contacts phone number
    Can I know what was the problem?
  2. willow
    willow Member
    Mar 1, 2011
    471
    Have you installed the Call assistant software which will install the 3cx tapi driver on the PC?
  3. fahim
    Apr 13, 2011
    6
    Yes I have installed Call Asistance Software. That's why I can make calls to lead's and contact's phone in salesforce. but I cannot make calls to mobile phones of Lead's and Contact's in Salesforce.
    Please help me to solve this problem
