Unable to Configure LinkSys 3102
Discussion in 'Windows' started by pschakravarthi, Oct 16, 2008.
  1. pschakravarthi
    May 21, 2008
    5
    I am a newbie to 3CX.
    I want to configuration details for Linksys 3102 to configure 3CX
    My 3cx Server is in a Private Network with IP is 193.88.201.33
    My 3CX Server is connected to internet.
    I want to connect Linksys 3102 from Internet.
    Please let me know how to do this setup.
    Regards
    Chakravarthi PS
  2. qaisdev
    Apr 7, 2008
    33
    You got me confused.
    Please can you clarify :
    a)What is the structure of you private network.
    b)What are u trying to achive by connecting 3102.
    Cheers
    Qais
  3. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello and welcome,
    First in 3cx Spa3102 settings change fxo pstn Gateway port to 5061
    Hard ware Version must be updated to 5.1.7(GW)
    From linksys site
    reset to factory set
    dial ****
    73738#
    Hangup
    dial 110# to know your web IP
    unplug power and plug again
    dial 7932# to enable web control
    click admin/advanced
    Click ROUTER/WAN SETUP
    Internet Connection Settings
    Change Connection Type: to static ip
    Static IP Settings
    : set your network parameters Static IP:,NetMask:,Gateway
    set dns provided from your ISP
    set ntp to ntp server (option)
    in pstn LINE
    SIP Settings
    leave SIP Port:5061 as it
    Proxy and Registration
    proxy:your server ip
    register expires:300
    Subscriber Information
    set user id and password
    Audio Configuration
    Preferred Codec: g729
    Dial Plans
    Dial Plan 8: (S0<:xxxxx>)
    which xxxxx= 3cx virtual number
    PSTN-To-VoIP Gateway Setup
    PSTN Ring Thru Line 1:No
    PSTN CID Number Prefix:eek:ption
    PSTN CID For VoIP CID: yes
    PSTN Caller Default DP: 8
    FXO Timer Values (sec)
    PSTN Answer Delay:From 4 to 6
    PSTN Disconnect Detection
    Detect PSTN Long Silence
    PSTN Long Silence Duration:300
    International Control
    Line-In-Use Voltage:10
    In LINE1
    proxy
    Audio Configuration
    Option to connect from remote to 3cx server
    In VOICE/SIp
    NAT Support Parameters
    STUN Enable: yes
    STUN Server: stun.fwdnet.net
    In pstn line
    Nat settings
    NAT Mapping Enable: yes
    In Line 1
    Nat settings
  4. pschakravarthi
    May 21, 2008
    5
    I want to connect my LinkSys 3102 as external extention.
    Regards
    Chakravarthi PS
  5. pschakravarthi
    May 21, 2008
    5
    Hi My Setup is
    my 3CX Server IP details
    IP 193.88.201.33
    Mask 255.255.255.0
    Gate way 193.88.201.10
    My DSL Modem IP Details
    IP 193.88.201.10
    Mask 255.255.255.0
    I have static IP
    59.xx.131.18
    I have opened the following ports in my DSL Modem
    5060 UDP/TCP 193.88.201.33
    5090 TCP 193.88.201.33
    9000-9015 UDP 193.88.201.33
    Firewall check is passed.
    My Internal Clients are able to register.
  6. galal202
    galal202 New Member
    Jun 23, 2008
    235
    THE DEFFERANCE BETWEEN ENTERNAL AND EXTERNAL (REMOTE) IS:
    In VOICE/SIp
    STUN Enable: yes
    In pstn line
    Nat settings
    In Line 1
    Nat settings
  7. qaisdev
    Apr 7, 2008
    33
    you have to make sure that sip.abc.com resolves to your 3cx box from the external network.
