Unable to connect to SipGate
Discussion in '3CX Phone System - General' started by fantawttw, Aug 19, 2006.
  1. fantawttw
    Aug 8, 2006
    7
    Many thanks for the great product.
    I have a problem through in that I cannot connect to sipgate, when I follow the instructions in the manual it shows me different screenshots to the web interface, I have tried a couple of times to get the system to connect through to sipgate however it never manages it.
    I have been through all the various menus looking for a way to modify the gateways, voip line etc and none of them seem to work.
    If you let me know what information you require from me to help me solve this problem I'd be gratefull.
    Kind regards
    Jon
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,991
    305
    SIPgate
    Thank you for your feedback.
    We are about to upload an improved manual today describing in more detail how to setup SIPgate with 3CX Phone System. In short however its important to put the right info from the SIPgate Connection information in the right fields of the 3CX VOIP provider lines:
    The value next to
