Unable to Dial Out
Discussion in '3CX Phone System - General' started by Flyer78, Feb 12, 2012.
  1. Flyer78
    Sep 28, 2007
    I am using a T.38 Fax service that is running on my print server. When the call out takes place you can see the IP's are different.I'm trying to figure out if there is a way to whitelist the IP to allow the call or what exactly is going on so that I can change what needs to be changed on the client side
    Address of my 3CX server: 10.0.0.102
    Address of the Fax Server: 10.0.0.3
    19:41:23.818 [CM502001]: Source info: From: "IPFax"<sip:211@10.0.0.3>;tag=IPF_PORT_0001_1003<sip:4038795050@10.0.0.102>
    19:41:23.818 [CM503013]: Call(8): Incoming call rejected, caller is unknown; msg=SipReq: INVITE 4038795050@10.0.0.102 tid=1005 cseq=INVITE contact=211@10.0.0.3:5060 / 2 from(wire)
    19:41:23.715 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:4038795050@10.0.0.102 SIP/2.0
    Via: SIP/2.0/UDP 10.0.0.3:5060;branch=z9hG4bK1004
    Max-Forwards: 70
    Contact: <sip:211@10.0.0.3:5060>
    To: <sip:4038795050@10.0.0.102>
    Call-ID: cbfa34cd-4948-47c4-bd2d-dcfee5063056@10.0.0.3
    CSeq: 1 INVITE
    Allow: INVITE, ACK, BYE, CANCEL, REFER, NOTIFY
    User-Agent: Net Satisfaxtion/IP_FAX-0.0.0.0
    Content-Length: 0
