Unable to dial outbound with Patton 4114
Discussion in '3CX Phone System - General' started by nplummer, May 17, 2012.
  1. nplummer
    May 14, 2010
    22
    We have an existing 3CX system which has been running for almost 2 years. We are running Version 10 SP6. We are testing a new Patton 4114 to use with our analog lines. The Patton has been updated to the most current firmware (6.1).
    We went through the configuration setup in the management console and exported the config file to the Patton device and imported it. After the Patton came back up we saw that it was registered with the system and ready for testing.
    Inbound calls function normally. However, dialing outbound we can see the green light on the Patton (line 1) light up for about 1 second, then the 3CX system gives an audible message of "Cancelled" and hangs up. We have verified that the outbound dialing rules are set correctly and we have rebooted the Patton a few times to make sure it is getting a good load of the config file.
    Below is a snippet from our loggs showing a call. Any help would be greatly appreciated.
    16:31:46.817 [CM503008]: Call(18869): Call is terminated
    16:31:43.770 Session 3389581 of leg C:18869.1 is confirmed
    16:31:43.426 [CM503007]: Call(18869): Device joined: sip:EndCall@127.0.0.1:40600;rinstance=edd21db396bc9fee
    16:31:43.426 [CM503007]: Call(18869): Device joined: sip:312@10.10.1.177:5060
    16:31:43.410 [MS210003] C:18869.1:Answer provided. Connection(transcoding mode[unsecure]):10.10.1.1:7244(7245)
    16:31:43.410 [MS210001] C:18869.3:Answer received. RTP connection[unsecure]: 127.0.0.1:40650(40651)
    16:31:43.410 Remote SDP is set for legC:18869.3
    16:31:43.410 [CM503002]: Call(18869): Alerting sip:EndCall@127.0.0.1:40600;rinstance=edd21db396bc9fee
    16:31:43.207 [CM503025]: Call(18869): Calling Unknown:Ext.EndCall@[Dev:sip:EndCall@127.0.0.1:40600;rinstance=edd21db396bc9fee]
    16:31:43.207 [MS210002] C:18869.3:Offer provided. Connection(transcoding mode): 127.0.0.1:7248(7249)
    16:31:43.207 [CM503016]: Call(18869): Attempt to reach <sip:45974800@10.10.1.1> failed. Reason: Request Terminated
    16:31:43.207 [CM503003]: Call(18869): Call to sip:5974800@10.10.1.178:5060 has failed; Cause: 487 Request Terminated; from IP:10.10.1.178:5060
    16:31:41.785 [CM503025]: Call(18869): Calling PSTNline:5974800@(Ln.10014@Analog Lines)@[Dev:sip:10014@10.10.1.178:5060]
    16:31:41.785 [MS210002] C:18869.2:Offer provided. Connection(transcoding mode): 10.10.1.1:7246(7247)
    16:31:41.738 [CM503004]: Call(18869): Route 1: PSTNline:5974800@(Ln.10014@Analog Lines)@[Dev:sip:10014@10.10.1.178:5060]
    16:31:41.738 [CM503010]: Making route(s) to <sip:45974800@10.10.1.1>
    16:31:41.738 [MS210000] C:18869.1:Offer received. RTP connection: 10.10.1.177:16002(16003)
    16:31:41.738 Remote SDP is set for legC:18869.1
    16:31:41.738 [CM505001]: Ext.312: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Panasonic_KX-UT670/01.022 (0080f0de3d3f)] PBX contact: [sip:312@10.10.1.1:5060]
    16:31:41.738 [CM503001]: Call(18869): Incoming call from Ext.312 to <sip:45974800@10.10.1.1>
    16:31:41.723 [CM500002]: Info on incoming INVITE:
    INVITE sip:45974800@10.10.1.1:5060 SIP/2.0
    Via: SIP/2.0/UDP 10.10.1.177:5060;branch=z9hG4bKs2e22950cf
    Max-Forwards: 70
    Contact: <sip:312@10.10.1.177:5060>
    To: <sip:45974800@10.10.1.1>
    From: "Nepal Plummer - 312"<sip:312@10.10.1.1>;tag=931388633
    Call-ID: d912ddc8-7caf411718ceaa21f0930080f0de3d3f@10.10.1.177
    CSeq: 2 INVITE
    Allow: INVITE, ACK, CANCEL, BYE, INFO, OPTIONS, NOTIFY, REFER
    Proxy-Authorization: Digest realm="3CXPhoneSystem",nonce="414d535c05c4c9dd25:c407ae28d729570cf4384c9091861670",algorithm=MD5,uri="sip:45974800@10.10.1.1:5060",username="312",response="dca32efe34e1ed20c5a1d325a6a6f3f7"
    Supported: replaces
    User-Agent: Panasonic_KX-UT670/01.022 (0080f0de3d3f)
    Thank You,
    Nepal
    Fahillion Technologies
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Did you make any changes to the outbound rules ie calls to numbers starting with prefix X,X,X,X,X,.. As well as the call coming from extionson 100-110?
  3. nplummer
    May 14, 2010
    22
    I contacted Patton and received an updated config file which modified the "low loop-break duration" setting. It was set at 60ms as the minimum and they suggested a modification to 200ms. After making that change to the config file I uploaded it and tested. Both inbound and outbound calls are functioning properly.
    Nepal Plummer
