Unable to disable external calls
Discussion in '3CX Phone System - General' started by foxco, Nov 16, 2011.
  1. foxco
    Sep 27, 2010
    My installation is up to date : 3Cx 10.0.22052.2264
    I create several extension,
    one management group
    And I would like to disable external call for several extensions.
    It's not possible to select the box, stay in gray...
    Do I miss something ?
    Thanks,
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    These options are not available in the free version. If you want this you need to buy a license or activate one if you purchased one.
    Thanks,
    Nate
