Unable to download call recordings via FQDN
Discussion in '3CX Phone System - General' started by Prawnapple, Feb 13, 2018.
  1. Prawnapple
    Jun 9, 2016
    14
    Hi There,
    I am getting the following error when I click on "download" after choosing a call recordings in 3cx at the call recordings tab:
    Code:
    System.NotSupportedException: The given path's format is not supported.
       at System.Security.Permissions.FileIOPermission.EmulateFileIOPermissionChecks(String fullPath)
       at System.Security.Permissions.FileIOPermission.QuickDemand(FileIOPermissionAccess access, String fullPath, Boolean checkForDuplicates, Boolean needFullPath)
       at ManagementConsoleJS.Controllers.RecordingListController.Download(String file)
       at lambda_method(Closure , Object , Object[] )
       at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.<InvokeActionFilterAsync>d__28.MoveNext()
    --- End of stack trace from previous location where exception was thrown ---
       at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
       at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.<InvokeAsync>d__18.MoveNext()
       at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
       at Microsoft.AspNetCore.Builder.RouterMiddleware.<Invoke>d__4.MoveNext()
       at ManagementConsoleJS.Middleware.ExceptionWrapperMiddleware.<Invoke>d__3.MoveNext()
    What could this mean or how can I fix it? Also, when I select multiple recordings it downloads an empty rar file. I am sending all recordings on a hosted server to a second drive D:/ (When I log into the server I can find any recording and download it)
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,448
    541
    Hello @Prawnapple
    What PBX version are you running and on what operating system? Is this a new installation? Did you restore from a backup? Is D:/ a local drive?
  3. Prawnapple
    Jun 9, 2016
    14
    Hi @YiannisH_3CX,
    Thanks for the the response, herewith the info required:
    Windows Server 2012 - 64 Bit Operating System
    3CX Phone System Professional Edition, 15.5.5
    Every one of the two drives is a virtual drive / internal physical drive
    This was a brand new installation a few months ago.
  4. YiannisH_3CX
    May 10, 2016
    7,448
    541
    Please check your inbox as i have sent you a p.m. regarding what is needed to further troubleshoot your issue.
