Unable to forward calls when using digital receiptionist
Discussion in '3CX Phone System - General' started by kchua, Sep 12, 2009.
  1. kchua
    Sep 12, 2009
    I have an extension which is set to forward to external number when no answer. This is working fine if I route calls to connect to this extension directly. However, it will fail to work if I route it to the digital receptionist, which in turn route to the extension based on the option selected. Below is the log generated when the call forwarding is works and is not working respectively. Any advise is deeply appreciated. Thanks.
    WORKING (ROUTE TO EXTENSION)
    17:32:14.472 [CM503008]: Call(39): Call is terminated
    17:32:03.837 [CM505003]: Provider:[Pfingo] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.1.100:5060]
    17:32:03.837 [CM503002]: Call(39): Alerting sip:kc@sip.pfingo.com:5060
    17:32:03.624 [CM503024]: Call(39): Calling VoIPline:92703102@(Ln.10000@Pfingo)@[Dev:sip:kc@sip.pfingo.com:5060]
    17:32:03.306 [CM503005]: Call(39): Forwarding: VoIPline:92703102@(Ln.10000@Pfingo)@[Dev:sip:kc@sip.pfingo.com:5060]
    17:31:48.484 [CM505001]: Ext.100: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 3.1.8571.0] Transport: [sip:192.168.1.100:5060]
    17:31:48.480 [CM503002]: Call(39): Alerting sip:100@192.168.1.100:61942;rinstance=1d5adbb2cf2dd3b6
    17:31:48.243 [CM503024]: Call(39): Calling Ext:Ext.100@[Dev:sip:100@192.168.1.100:61942;rinstance=1d5adbb2cf2dd3b6]
    17:31:48.190 [CM503004]: Call(39): Route 1: Ext:Ext.100@[Dev:sip:100@192.168.1.100:61942;rinstance=1d5adbb2cf2dd3b6]
    17:31:48.189 [CM503010]: Making route(s) to <sip:100@192.168.1.100:5060>
    17:31:48.184 [CM505003]: Provider:[Pfingo] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [GRSIPGateway V 3.2.0 080606] Transport: [sip:192.168.1.100:5060]
    17:31:48.146 [CM503001]: Call(39): Incoming call from 63100203@(Ln.10000@Pfingo) to <sip:100@192.168.1.100:5060>
    17:31:47.502 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10000 forwards to DN:100
    17:31:27.826 [CM504004]: Registration succeeded for: 10000@Pfingo
    17:31:27.654 [CM504003]: Sent registration request for 10000@Pfingo
    17:31:26.064 [CM504004]: Registration succeeded for: 10000@Pfingo
    17:31:25.818 [CM504003]: Sent registration request for 10000@Pfingo
    17:28:25.984 [CM504008]: Fax Service: registered as sip:888@192.168.1.100:5060 with contact sip:888@192.168.1.100:5100;user=phone
    17:28:16.503 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 75.101.138.128:3478 over Transport 192.168.1.100:5060
    NOT WORKING (ROUTE TO DIGITAL RECEPTIONIST THEN EXTENSION)
    17:24:14.548 [CM503008]: Call(38): Call is terminated
    17:24:14.539 [CM503008]: Call(38): Call is terminated
    17:24:07.775 [CM503015]: Call(38): Attempt to reach <sip:100@127.0.0.1:5060> failed. Reason: Forbidden
    17:24:07.775 [CM503003]: Call(38): Call to sip:92703102@sip.pfingo.com:5060 has failed; Cause: 603 Decline; from IP:203.117.31.243:5060
    17:24:07.716 [CM505003]: Provider:[Pfingo] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.1.100:5060]
    17:24:07.716 [CM503002]: Call(38): Alerting sip:kc@sip.pfingo.com:5060
    17:24:07.468 [CM503024]: Call(38): Calling VoIPline:92703102@(Ln.10000@Pfingo)@[Dev:sip:kc@sip.pfingo.com:5060]
    17:24:07.121 [CM503005]: Call(38): Forwarding: VoIPline:92703102@(Ln.10000@Pfingo)@[Dev:sip:kc@sip.pfingo.com:5060]
    17:23:52.231 [CM505001]: Ext.100: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 3.1.8571.0] Transport: [sip:192.168.1.100:5060]
    17:23:52.231 [CM503002]: Call(38): Alerting sip:100@192.168.1.100:61942;rinstance=1d5adbb2cf2dd3b6
    17:23:52.044 [CM503024]: Call(38): Calling Ext:Ext.100@[Dev:sip:100@192.168.1.100:61942;rinstance=1d5adbb2cf2dd3b6]
    17:23:51.974 [CM503004]: Call(38): Route 1: Ext:Ext.100@[Dev:sip:100@192.168.1.100:61942;rinstance=1d5adbb2cf2dd3b6]
    17:23:51.973 [CM503010]: Making route(s) to <sip:100@127.0.0.1:5060>
    17:23:51.968 [CM505003]: Provider:[Pfingo] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [GRSIPGateway V 3.2.0 080606] Transport: [sip:192.168.1.100:5060]
    17:23:40.750 [CM503007]: Call(38): Device joined: sip:800@127.0.0.1:40600;rinstance=710fd82e0600939e
    17:23:40.712 [CM503007]: Call(38): Device joined: sip:63100203@203.117.31.251:6889
    17:23:40.672 [CM505001]: Ext.800: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] Transport: [sip:127.0.0.1:5060]
    17:23:40.672 [CM503002]: Call(38): Alerting sip:800@127.0.0.1:40600;rinstance=710fd82e0600939e
    17:23:40.219 [CM503024]: Call(38): Calling Ext:Ext.800@[Dev:sip:800@127.0.0.1:40600;rinstance=710fd82e0600939e]
    17:23:40.151 [CM503004]: Call(38): Route 1: Ext:Ext.800@[Dev:sip:800@127.0.0.1:40600;rinstance=710fd82e0600939e]
    17:23:40.150 [CM503010]: Making route(s) to <sip:800@192.168.1.100:5060>
    17:23:40.129 [CM505003]: Provider:[Pfingo] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [GRSIPGateway V 3.2.0 080606] Transport: [sip:192.168.1.100:5060]
    17:23:40.115 [CM503001]: Call(38): Incoming call from 63100203@(Ln.10000@Pfingo) to <sip:800@192.168.1.100:5060>
    17:23:39.794 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10000 forwards to DN:800
    17:23:25.774 [CM504008]: Fax Service: registered as sip:888@192.168.1.100:5060 with contact sip:888@192.168.1.100:5100;user=phone
  2. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    Code:
    Do you have all the rules setup for call handling?
