Unable to get incoming calls
Discussion in '3CX Phone System - General' started by 5qg4, Dec 17, 2007.
  1. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Anyone hit this issue? I cannot get incoming calls.
    3CX Version5.0.3648.0 and Patch for Version 5.0.3648 applied
    Gateway is Patton SN4960
    Please find the system status log in verbose mode as below:
    05:30:43.193 evt::CheckIfAuthIsRequired::not_handled [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    05:30:43.193 evt::CheckIfAuthIsRequired::not_handled [CM302001]: Authorization system can not identify source of: SipReq: INVITE 305@10.1.1.10 tid=10d1d319c cseq=INVITE contact=928739573@10.1.1.229:5062 / 429314695 from(wire)
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Problem solved. :D
  3. AldoLinares
    AldoLinares New Member
    Nov 12, 2007
    135
    how do you solve it?
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Remove unwanted condition rules at service hunt-group. But those rules works fine at V3. Strange :(
