Solved Unable to get push notifications to work samsung s7 3cx client android
Discussion in 'Android' started by Zimstyles, Apr 14, 2017.
  1. Zimstyles
    Apr 14, 2017
    So I am currently testing out the 3CX Cloud using the provided OVH hosting. The environment is working well, I can receive calls, make calls carry out transfers etc.
    For testing I have two iOS devices - push works perfectly every single time.
    Android - I am testing using a Samsung S7 Edge Android 6.01
    The client is 15.0.71
    I have tried to use the 3CX GCM, tried Firebase, and tried the old GCM. All methods will not work for push on this device.
    I have re provisioned at each step, deleted the account, re configured nothing.
    Can someone help me.
    04/14/2017 11:07:52 AM - Updating device Dev(2118309278):[sip:11@127.0.0.1:5488;rinstance=f46f3ba2e96c1f99 / 11] by message: DevUpd Recv Req REGISTER from 127.0.0.1:5488 tid=dd6c8c6d6ecd4c7d Call-ID=bFx8l2WlcbN-QQd2tA4aAA..:
    REGISTER sip:abcdef.3cx.co.za SIP/2.0
    Via: SIP/2.0/UDP 127.0.0.1:5488;branch=z9hG4bK-524287-1---dd6c8c6d6ecd4c7d;rport=5488
    Max-Forwards: 70
    Contact: <sip:11@127.0.0.1:5488;rinstance=f46f3ba2e96c1f99>
    To: "Push for 11"<sip:11@abcdef.3cx.co.za>
    From: "Push for 11"<sip:11@abcdef.3cx.co.za>;tag=facb2a1b
    Call-ID: bFx8l2WlcbN-QQd2tA4aAA..
    CSeq: 54 REGISTER
    Expires: 120
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
    Proxy-Authorization: Digest username="11",realm="3CXPhoneSystem",nonce="414d535958f0916791:b57605f66f8a0a1b3f381a495b3fc45f",uri="sip:abcdef.3cx.co.za",response="cd9a258303646acad3c3d0907608cdc6",algorithm=MD5
    Supported: replaces
    User-Agent: 3CX Push Service
    Content-Length: 0
    04/14/2017 11:07:51 AM - Caller "Push for 10"<sip:10@abcdef.3cx.co.za>;tag=a274cd38 has been authenticated successfully from IP 127.0.0.1
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Hello @Zimstyles
    What version PBX do you have? Can you tell me the version or service pack you are on?
    If you are SP5 or prior then:
    Please navigate to Dashboard / Activity Log / Options and set logging to verbose. Restart all 3CX services. try making a call to the extension with the Push.
    then generate the support info from the support tab.
    Open the support info bundle and navigate to the Logs folder, locate the 3CXDialer.log and search for the call. You should see the error that caused the call to fail. If you see OK OK then the Push message succeeded and you should search for the error on the device (power options, notifications etc).
    Also check the guide for android push and make sure the settings are correct with your project.
    https://www.3cx.com/docs/configuring-google-push/
    If you are on V15.5 then please note that you have to wait for the new client to come out as the .71 client does not work with V15.5.
    #2 YiannisH_3CX, Apr 14, 2017
  3. AH2
    AH2 New Member
    Mar 14, 2017
    109
    When can we expect the new client for android ? for me the upgrade was installed on server reboot and left me down on all android devices.
    Thanks.
  4. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    240
    12
  5. Freddy Larsen
    Feb 1, 2017
    7
    But on my samsung galaxy s6 the new beta android app 15.1.04 is not recieving push from our server, wich is not upgraded to SP5 yet. The original from play store v. 15.0.71 is fully functionally with push from our server, not upgraded to SP5 yet..
    /Freddy
  6. YiannisH_3CX
    May 10, 2016
    4,349
    274
  7. Mike Brauch
    Mar 7, 2017
    5
    I am currently using the pbx - sending welcoming emails to my employees and they download the file but get failed register errors. I did my phone and it connects fine. I checked all the settings in 3cx server management and made same as mine. It knows who they are but won't connect. Ideas?
    I have double checked all the server settings - my phone just like their identically - but theirs will not register.
    #7 Mike Brauch, May 17, 2017
  8. Marios Neophytou
    Mar 1, 2016
    240
    12
    Hello @Mike Brauch,
    1. Can you check if your clients are connected through tunnel? (Management Console > Click on an extension > Go to Phone Provisioning > Use 3CX Tunnel for remote connections (3CX Client only) ) .
    2. Also, can you please tell us what version of PBX and Android client are you currently running?
    Thank You
  9. Mike Brauch
    Mar 7, 2017
    5
    Marios - I was able to figure it out. It had to do with connecting to our wireless behind the firewall - we have to connect this way and it registered and controls the phone.
