Unable to hear calls through earpiece
Discussion in 'iOS' started by Ozyank, Jun 1, 2012.
  1. Ozyank
    Jun 1, 2012
    I have just noticed that I am unable to hear my calls through the earpiece of the iPhone 4S, although the speaker works. I tried another softphone, Dialer+ and got the same result. My provider is voip.ms
    I have not contacted the provider and suspect it might be a problem with the 4S. Has anyone ever heard of this?
    Device Info
    Phone Model: iPhone
    Generation: 4S (WiFi or GSM)
    Firmware Version: 5.1.1
    Jailbreak: NO
    Cydia Installed: NO
    10,368
    228
    If another app is doing the same thing, then I too would suspect the phone, app conflict?. If it worked previously, have you tried powering down and back up, or even taking out the battery to see if that has any affect?
  3. StefanW
    Jun 2, 2009
    1,199
    79
    this seams to be a bit odd, due to the audio stream is for EP or SP the same from the sip point of view.
    we send it to the device and it should play it.
    Allow me the question if your 4s is jailbroken or not?
    JB massively changes routings in the phone...
  4. LCC
    LCC
    Jul 8, 2011
    42
    The exact same thing happens to me. I also have voip.ms. Works fine with no earpiece, but when I plug a headset in, it does not work. Works fine for all other apps. I have an iPhone 4, not jailbroken.
