Unable to load DLL 'tcxpscom_native' error for v15
Discussion in '3CX Phone System - General' started by jamesdesouza, Mar 1, 2017.
  1. jamesdesouza
    Jan 23, 2015
    5
    I tried to upgrade my custom app to v15 but I get error on initialize of app.
    I've done everything on sample project to connect.
    Here is my code:
    Code:
    class Connector3CXv15
            static string instanceBinPath;
            public static void Bootstrap()
                try
                    var filePath = @"C:\Program Files\3CX Phone System\Instance1\Bin\3CXPhoneSystem.ini";
                    if (!File.Exists(filePath))
                        //this code expects 3CXPhoneSystem.ini in current directory.
                        //it can be taken from the installation folder (find it in Program Files/3CXPhone System/instance1/bin for in premiss installation)
                        //or this application can be run with current directory set to location of 3CXPhoneSystem.ini
                        //v14 (cloud and in premiss) installation has changed folder structure.
                        //3CXPhoneSystem.ini which contains connectio information is located in
                        //<Program Files>/3CX Phone System/instanceN/Bin folder.
                        //in premiss instance files are located in <Program Files>/3CX Phone System/instance1/Bin
                        throw new Exception("Cannot find 3CXPhoneSystem.ini");
                    instanceBinPath = Path.Combine(GetKeyValue("General", "AppPath", filePath), "Bin");
                    //AppDomain.CurrentDomain.AssemblyResolve += CurrentDomain_AssemblyResolve;
                    Connect(filePath);
                catch (Exception ex)
                    Console.WriteLine(ex.ToString());
            public static bool Connect(string filePath)
                    var a = new Random(Environment.TickCount);
                    //unique name PhoneSystem.ApplicationName = "TestApi";//any name
                    PhoneSystem.ApplicationName = "Connector3CXv15" + a.Next().ToString();
                #region phone system initialization(init db server)
                var value = GetKeyValue("ConfService", "ConfPort", filePath);
                var port = 0;
                PhoneSystem.CfgServerHost = "127.0.0.1";
                if (!string.IsNullOrEmpty(value))
                    int.TryParse(value.Trim(), out port);
                    PhoneSystem.CfgServerPort = port;
                value = GetKeyValue("ConfService", "confUser", filePath);
                    PhoneSystem.CfgServerUser = value;
                value = GetKeyValue("ConfService", "confPass", filePath);
                    PhoneSystem.CfgServerPassword = value;
                #endregion
                var dns = PhoneSystem.Root.GetDN(); //Access PhoneSystem.Root to initialize ObjectModel
                //SampleStarter.StartSample(args);
                //PhoneSystem.Root.Disconnect();
                return PhoneSystem.Root.Connected;
            static Assembly CurrentDomain_AssemblyResolve(object sender, ResolveEventArgs args)
                var name = new AssemblyName(args.Name).Name;
                if (name == "3cxpscomcpp2")
                    return Assembly.LoadFrom(Path.Combine(instanceBinPath, name + ".dll"));
                else
                    throw new FileNotFoundException();
            [DllImport("kernel32.dll", EntryPoint = "GetPrivateProfileStringA")]
            static extern int GetKeyValueA(string strSection, string strKeyName, string strNull, StringBuilder RetVal, int nSize, string strFileName);
            static public string GetKeyValue(string Section, string KeyName, string FileName)
                //Reading The KeyValue Method
                try
                    StringBuilder JStr = new StringBuilder(255);
                    int i = GetKeyValueA(Section, KeyName, String.Empty, JStr, 255, FileName);
                    return JStr.ToString();
                catch (System.Exception e)
                    throw e;
            public static string GetParameterValue(string name, string DefaultValue, ref bool exists)
                try
                    exists = true;
                    return TCX.Configuration.PhoneSystem.Root.GetParameterByName(name).Value;
                catch
                    exists = false;
                    return DefaultValue;
    In addition, I'm using Topshelf library.
    How should I solve this problem?
    I can not connect even with the code below
    Code:
    PhoneSystem.CfgServerPort = 5485;
    PhoneSystem.CfgServerUser = "cfguser_default";
    PhoneSystem.CfgServerPassword = "z320xszg1lj";
    I got the same error at .Root property.
    #1 jamesdesouza, Mar 1, 2017
  2. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Maybe you need to change or Set the Copy Local Property of a Reference?:confused:
  3. HurricaneH
    May 31, 2017
    Did you ever get beyond this problem. I'm wrestling with it now. Also interested in best practices or leassons learned to test within Visual Studio
  4. jamesdesouza
    Jan 23, 2015
    5
