unable to log into 3cx free management console after install
Discussion in '3CX Phone System - General' started by olpa99011, May 29, 2007.
  1. olpa99011
    May 29, 2007
    I am running Win2k sp4, 3.4ghz p4, 1 gig ram, and excessive amounts of hard drive space.
    also running on the machine is IIS, hosting 3 really really low traffic sites, with php5 and pearl.
    When i click on the management icon in the start folder or i navigate to localhost and appropriate port, it just times out. i don't see IIS using the same ports, so i am unsure what is going on. I have also uninstalled and reinstalled and both times, the 3cx webserver hangs on starting in the services snapin, however when you check it after a reboot, it is running fine.
    Thanks in advance for any help!
    Pat
    attached are the logs.
    here is the log from the 3cxiserver
    2007/05/26 >>
    11:42:03.187|0408|.\3CXIvrService.cpp(817):IvrService, main(), Starting service, revision 3.0.1928.0
    11:42:03.218|0474|.\VoiceMenuCreator.cpp(593):VMCreator, VxmlCreatorSetLog(), External log has been set for VoiceMenuCreator dll
    11:42:03.218|0474|.\VoiceMenuCreator.cpp(37):VMCreator, CVoiceMenuCreator::Init(), Initializing, revision 3.0.1928.0
    11:42:04.156|0474|.\3CXIvrService.cpp(572):IvrService, MainServiceProc::Run(), Initializing php updater
    11:42:04.171|0474|.\3CXIvrService.cpp(581):IvrService, MainServiceProc::Run(), Writing global parameters to php ...
    11:42:04.171|0474|.\VoiceMenuCreator.cpp(235):VMCreator, CVoiceMenuCreator::DBConnect(), Connecting to database ...
    11:42:04.171|0474|.\DBAccessor.cpp(547):VMCreator, CDBAccessor::Connect(), Database connect string [dbname=phonesystem port=5480 user=phonesystem password=EF11C93F-3E70-4D6E-A2C9-AC87944EC028]
    11:42:04.375|0474|.\DBAccessor.cpp(586):VMCreator, CDBAccessor::Connect(), Database connection success
    11:42:16.390|0474|.\IVR_Api.cpp(631):IvrDll, Ivr_SetLog(), External log has been set for IVR dll
    11:42:16.390|0474|.\IVR_Api.cpp(311):IvrDll, IVRApi::Init(), Initializing, revision 3.0.1928.0
    11:42:16.406|0474|.\IVR_Api.cpp(172):IvrDll, IVRApi::LoadConfiguration(), Using config file 'C:\Program Files\3CX PhoneSystem\Bin\..\Data\Ivr\Cfg\3CXIvr.cfg'
    11:42:16.468|0474|.\IVR_Api.cpp(206):IvrDll, IVRApi::LoadConfiguration(), Default vxml document: 'http://localhost:5481/Vxml/ivr_start.php'
    11:42:16.468|0474|.\IVR_Api.cpp(232):IvrDll, IVRApi::LoadConfiguration(), Prompts URL: 'http://localhost:5481/Vxml/prompts'
    11:42:16.468|0474|.\IVR_Api.cpp(258):IvrDll, IVRApi::LoadConfiguration(), Using beep URI 'file:///C%7c/Program%20Files/3CX%20PhoneSystem/Bin/%2e%2e/Data/Ivr/Media/beep%2ewav'
    11:42:16.468|0474|.\IVR_Api.cpp(280):IvrDll, IVRApi::LoadConfiguration(), Using error message URI 'file:///C%7c/Program%20Files/3CX%20PhoneSystem/Bin/%2e%2e/Data/Ivr/Media/error%2emp3'
    11:42:16.468|0474|.\IVR_Api.cpp(298):IvrDll, IVRApi::LoadConfiguration(), Using inet cache dir 'C:\Program Files\3CX PhoneSystem\Bin\..\Data\Ivr\Cache'
    11:42:16.906|0474|.\3CXIvrService.cpp(660):IvrService, MainServiceProc::Run(), Service started
    11:42:17.468|0b24|..\..\PbxServer\MSInterface.cpp(637):Media Server is connected
    11:42:18.015|0b34|.\SLAgent.cpp(81):IvrService, SLAgent::Run(), Error! Cannot connect to 127.0.0.1:5482 SL server
    11:42:24.031|0b34|.\SLAgent.cpp(81):IvrService, SLAgent::Run(), Error! Cannot connect to 127.0.0.1:5482 SL server
    11:42:29.031|0b34|.\SLAgent.cpp(75):IvrService, SLAgent::Run(), Reconnected to 127.0.0.1:5482 SL server
    Mediaserver log:
    2007/05/26 >>
    11:42:00.312|Service.cpp(207)|Log2||??:*** Initialize ***
    11:42:00.328|Service.cpp(230)|Log2||??:Local port range is set to:7000-7499
    11:42:00.328|Service.cpp(245)|Log2||??:External port range is set to:9000-9003
    11:42:00.343|Service.cpp(289)|Log2||??:*** Start Server ***
    11:42:00.343|Service.cpp(49)|Log2||??:*** Listen ***
    11:42:00.343|Service.cpp(66)|Log2||??:*** Connecting to [127.0.0.1:5482] ***
    11:42:01.500|Service.cpp(78)|Log2||??:CM not found on 127.0.0.1:5482
    11:42:01.500|Service.cpp(92)|Log2||??:*** Connecting to [127.0.0.1:5483] ***
    11:42:02.593|Service.cpp(103)|Log2||??:IVR not found on 127.0.0.1:5483
    11:42:03.593|Service.cpp(66)|Log2||??:*** Connecting to [127.0.0.1:5482] ***
    11:42:04.671|Service.cpp(78)|Log2||??:CM not found on 127.0.0.1:5482
    11:42:04.671|Service.cpp(92)|Log2||??:*** Connecting to [127.0.0.1:5483] ***
    11:42:05.859|Service.cpp(103)|Log2||??:IVR not found on 127.0.0.1:5483
    11:42:06.859|Service.cpp(66)|Log2||??:*** Connecting to [127.0.0.1:5482] ***
    11:42:07.953|Service.cpp(78)|Log2||??:CM not found on 127.0.0.1:5482
    11:42:07.953|Service.cpp(92)|Log2||??:*** Connecting to [127.0.0.1:5483] ***
    11:42:09.046|Service.cpp(103)|Log2||??:IVR not found on 127.0.0.1:5483
    11:42:10.046|Service.cpp(66)|Log2||??:*** Connecting to [127.0.0.1:5482] ***
    11:42:11.125|Service.cpp(78)|Log2||??:CM not found on 127.0.0.1:5482
    11:42:11.125|Service.cpp(92)|Log2||??:*** Connecting to [127.0.0.1:5483] ***
    11:42:12.218|Service.cpp(103)|Log2||??:IVR not found on 127.0.0.1:5483
    11:42:13.218|Service.cpp(66)|Log2||??:*** Connecting to [127.0.0.1:5482] ***
    11:42:14.296|Service.cpp(78)|Log2||??:CM not found on 127.0.0.1:5482
    11:42:14.296|Service.cpp(92)|Log2||??:*** Connecting to [127.0.0.1:5483] ***
    11:42:15.390|Service.cpp(103)|Log2||??:IVR not found on 127.0.0.1:5483
    11:42:16.390|Service.cpp(66)|Log2||??:*** Connecting to [127.0.0.1:5482] ***
    11:42:17.468|Service.cpp(78)|Log2||??:CM not found on 127.0.0.1:5482
    11:42:17.468|Service.cpp(92)|Log2||??:*** Connecting to [127.0.0.1:5483] ***
    11:42:17.468|Service.cpp(97)|Log2||??:*** Connected to veranda:5483/IVRServer at 127.0.0.1:5483 ***
    11:42:18.468|Service.cpp(66)|Log2||??:*** Connecting to [127.0.0.1:5482] ***
    11:42:19.546|Service.cpp(78)|Log2||??:CM not found on 127.0.0.1:5482
    11:42:20.546|Service.cpp(66)|Log2||??:*** Connecting to [127.0.0.1:5482] ***
    11:42:21.625|Service.cpp(78)|Log2||??:CM not found on 127.0.0.1:5482
    11:42:22.625|Service.cpp(66)|Log2||??:*** Connecting to [127.0.0.1:5482] ***
    11:42:23.703|Service.cpp(78)|Log2||??:CM not found on 127.0.0.1:5482
    11:42:24.718|Service.cpp(66)|Log2||??:*** Connecting to [127.0.0.1:5482] ***
    11:42:24.718|Service.cpp(71)|Log2||??:*** Connected to veranda:5482/CallManager at 127.0.0.1:5482 ***
    and lastly phonesystem log
    2007/05/26 >>
    11:42:23.375|.\CallMgr.cpp(365)|Log2||LoadLicenceInfo:Licence loading error
    11:42:23.406|.\CallMgr.cpp(69)|Log2|CallManager|CallMgr::Initialize:Start 3CX PhoneSystem Call Manager
    11:42:23.406|.\CallMgr.cpp(70)|Log2|CallManager|CallMgr::Initialize:Version: 3.0.1928.0
    11:42:23.421|.\CallMgr.cpp(78)|Log2|CallManager|CallMgr::Initialize:** Initializing SIP stack **
    11:42:23.484|.\CM_Stack.cpp(24)|Log2|SipStack|CallMgr::Stack::Initialize:** Adding transports **
    11:42:24.421|.\CallMgr.cpp(190)|Log2|DUM|CallMgr::DumThread::thread:** Enter DUM Thread **
    11:42:24.578|.\DBAccessor.cpp(69)|Log2||DBA:** Database connection Ok **
    11:42:24.718|.\SLServer.cpp(21)|Log2||ListenConnect:SL: connected veranda:0/MediaServer at [veranda]/MediaServer
    11:42:24.718|.\MSInterface.cpp(637)|Log2||MediaServerConnected:Media Server is connected
    11:42:26.843|.\CM_Stack.cpp(85)|Log2|SipStack|CallMgr::Stack::thread:** Enter Stack Loop **
    11:42:28.703|.\SLServer.cpp(21)|Log2||ListenConnect:SL: connected veranda:0/VoiceBoxManagerService at [veranda]/VoiceBoxManagerService
    11:42:29.031|.\SLServer.cpp(21)|Log2||ListenConnect:SL: connected veranda:5483/IVRServer at [veranda]/IVRServer
    11:42:29.031|.\IVRInterface.cpp(249)|Log2||IVRConnected:IVR Server is connected
  2. Anonymous
    Anonymous Guest
    Have you tried restarting your machine?
    When 3cx installs it also installs its "web server" component so you might want to do a reboot.
    also check if you are using the correct port. I believe http://[yourIP address]:5481/login.php is standard, unless you changed the port. Just noticed that yours is on [5480] so try http://[yourIP address]:5480/login.php
    There are a few cases here and there that had issues with installing 3cx on a IIS machine running PHP5, but in the end it worked out.
    What I did when I installed 3cx was,
    turning off all the IIS/php/apache sites
    install 3cx
    reboot
    enable all the IIS/PHP/Apache sites
    and it just worked.
  3. olpa99011
    May 29, 2007
    same
    tried all of that, still no luck. the web browser says "connection reset" when i try to navigate to the admin site, fyi.
    here is my apache log too, seems some php errors?
    [Tue May 29 17:46:18 2007] [notice] Apache/2.0.58 (Win32) PHP/5.1.4 configured -- resuming normal operations
    [Tue May 29 17:46:18 2007] [notice] Server built: Apr 29 2006 17:47:10
    [Tue May 29 17:46:18 2007] [notice] Parent: Created child process 3468
    PHP Warning: PHP Startup: bz2: Unable to initialize module\nModule compiled with module API=20050922, debug=0, thread-safety=1\nPHP compiled with module API=20060613, debug=0, thread-safety=1\nThese options need to match\n in Unknown on line 0
    PHP Warning: PHP Startup: gd: Unable to initialize module\nModule compiled with module API=20050922, debug=0, thread-safety=1\nPHP compiled with module API=20060613, debug=0, thread-safety=1\nThese options need to match\n in Unknown on line 0
    PHP Warning: PHP Startup: pgsql: Unable to initialize module\nModule compiled with module API=20050922, debug=0, thread-safety=1\nPHP compiled with module API=20060613, debug=0, thread-safety=1\nThese options need to match\n in Unknown on line 0
    PHP Warning: PHP Startup: PDO: Unable to initialize module\nModule compiled with module API=20050922, debug=0, thread-safety=1\nPHP compiled with module API=20060613, debug=0, thread-safety=1\nThese options need to match\n in Unknown on line 0
    PHP Warning: PHP Startup: Unable to load dynamic library 'C:\\Program Files\\3CX PhoneSystem\\Bin\\Php\\extensions\\php_pdo_pgsql.dll' - The specified module could not be found.\r\n in Unknown on line 0
    PHP Warning: PHP Startup: xsl: Unable to initialize module\nModule compiled with module API=20050922, debug=0, thread-safety=1\nPHP compiled with module API=20060613, debug=0, thread-safety=1\nThese options need to match\n in Unknown on line 0
    PHP Warning: PHP Startup: cmstatus: Unable to initialize module\nModule compiled with module API=20050922, debug=0, thread-safety=1\nPHP compiled with module API=20060613, debug=0, thread-safety=1\nThese options need to match\n in Unknown on line 0
    PHP Warning: PHP Startup: phpSHIELD: Unable to initialize module\nModule compiled with module API=20050922, debug=0, thread-safety=1\nPHP compiled with module API=20060613, debug=0, thread-safety=1\nThese options need to match\n in Unknown on line 0
    [Tue May 29 17:46:34 2007] [notice] Child 3468: Child process is running
    [Tue May 29 17:46:34 2007] [notice] Child 3468: Acquired the start mutex.
    [Tue May 29 17:46:34 2007] [notice] Child 3468: Starting 250 worker threads.
    [Tue May 29 17:48:57 2007] [notice] Apache/2.0.58 (Win32) PHP/5.1.4 configured -- resuming normal operations
    [Tue May 29 17:48:57 2007] [notice] Server built: Apr 29 2006 17:47:10
    [Tue May 29 17:48:57 2007] [notice] Parent: Created child process 1752
    [Tue May 29 17:48:58 2007] [notice] Child 1752: Child process is running
    [Tue May 29 17:48:58 2007] [notice] Child 1752: Acquired the start mutex.
    [Tue May 29 17:48:58 2007] [notice] Child 1752: Starting 250 worker threads.
    [Tue May 29 18:04:09 2007] [notice] Parent: child process exited with status 3221225477 -- Restarting.
    [Tue May 29 18:04:09 2007] [notice] Apache/2.0.58 (Win32) PHP/5.1.4 configured -- resuming normal operations
    [Tue May 29 18:04:09 2007] [notice] Server built: Apr 29 2006 17:47:10
    [Tue May 29 18:04:09 2007] [notice] Parent: Created child process 4548
    [Tue May 29 18:04:09 2007] [notice] Child 4548: Child process is running
    [Tue May 29 18:04:09 2007] [notice] Child 4548: Acquired the start mutex.
    [Tue May 29 18:04:09 2007] [notice] Child 4548: Starting 250 worker threads.
    [Tue May 29 18:06:57 2007] [notice] Parent: child process exited with status 3221225477 -- Restarting.
    [Tue May 29 18:06:57 2007] [notice] Apache/2.0.58 (Win32) PHP/5.1.4 configured -- resuming normal operations
    [Tue May 29 18:06:57 2007] [notice] Server built: Apr 29 2006 17:47:10
    [Tue May 29 18:06:57 2007] [notice] Parent: Created child process 1632
    [Tue May 29 18:06:58 2007] [notice] Child 1632: Child process is running
    [Tue May 29 18:06:58 2007] [notice] Child 1632: Acquired the start mutex.
    [Tue May 29 18:06:58 2007] [notice] Child 1632: Starting 250 worker threads.
    [Tue May 29 18:07:14 2007] [notice] Parent: child process exited with status 3221225477 -- Restarting.
    [Tue May 29 18:07:14 2007] [notice] Apache/2.0.58 (Win32) PHP/5.1.4 configured -- resuming normal operations
    [Tue May 29 18:07:14 2007] [notice] Server built: Apr 29 2006 17:47:10
    [Tue May 29 18:07:14 2007] [notice] Parent: Created child process 2044
    [Tue May 29 18:07:14 2007] [notice] Child 2044: Child process is running
    [Tue May 29 18:07:14 2007] [notice] Child 2044: Acquired the start mutex.
    [Tue May 29 18:07:14 2007] [notice] Child 2044: Starting 250 worker threads.
  4. Anonymous
    Anonymous Guest
    Bugger,
    Now I don't know. I ll have to leave this to one of the 3cx guys. I have no idea why it does do a browser reset.
    Sorry.
  5. olpa99011
    May 29, 2007
    got it
    changed the php dll file to something different and it now works. guess it doesn't like having two of them. I just changed how IIS calls it and now everything is in harmony!
    yay
  6. Anonymous
    Anonymous Guest
    Ahh,
    That rings a bell, anyway good to hear you are on your way :).
  7. arusi
    Jun 9, 2007
    Hi!!
    I've the same problem here! How did you fix it?
    thanks!!!
    Windows 2000 A.Server SP4
  8. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,875
    171
    There is currently a problem if there are 2 PHP installs on the same machine. Its a trivial problem to fix, and its fixed in the new build we are releasing this week. Sorry about the inconvenience.
