Unable to login with 3CX Client - Authentification failed
Discussion in '3CX Phone System - General' started by cyberlex7, Sep 6, 2008.
  1. cyberlex7
    Jul 12, 2008
    19
    I checked 3 times my login password, and i can't manage to login in order to use the phone.
    Here's the error message which is displayed in the Server console of 3CX.
    [CM102001]: Authentication failed for SipReq: REGISTER my.server.com:5060 tid=c042b630ba549267 cseq=REGISTER contact=201@45.25.85.63:5070 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    Does someone have any idea ?,
    Thanks for help,
    Alex.
  2. cyberlex7
    Jul 12, 2008
    19
    Hello matlandis,
    Thank you for your help.
    I'm trying to connect to remote 3CX IP PBX with the 3CX Voip Client.
  3. amygoda
    amygoda Member
    Sep 18, 2006
    436
    retype the password on both sides
    server and client
  4. cyberlex7
    Jul 12, 2008
    19
    I've already tried but i still experience this issue :( - it's really incredible !
  5. cyberlex7
    Jul 12, 2008
    19
    [​IMG]
    Office hours are active
    Stun server is disabled - 3CX Machine is running on a dedicated machine, without firewall.
    Thank you so much for your help,
    If you need any aother info, don't hesitate to ask.
    REgards,
    Alex.
  6. cyberlex7
    Jul 12, 2008
    19
  7. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    Please go in the 3X configuration under the extension properties, and set the Pin number in the Voice Mail Configuration to be the same as the password (make it all numeric)
    Save settings and retry connecting with the 3CX client.
    regards
