- Joined
- Nov 1, 2007
- Messages
- 1
- Reaction score
- 0
I installed 3CX PBX on my system and have configured 4 lines(extension)
I have also added a SIP line from my provider VoiceStick to get connected to PSTN network. I have a rule which says that forward the call to my VoiceStick line if any number starts with 9.
Now I am unable to make any call. All calls (including calls with in extension and calls through VoiceStick are getting forbidden (403). Here is the log. Please somebody help to identify the issue and get my setup working.
Log for extension to extension calls:
CallConf::Rejected [CM103005] Call(11) is rejected: This line disallows incoming calls
10:40:05.703 Endpoint::findSource [CM010001] Line configuration does not allow identification of the source of this call. Check Advanced Options for Gateways and Providers and match a field to a correct value from the following: Contact IP: '65.XXX.XX.XXX'; From: '400'; To: '300'; Rline: '300'; Contact: '400'
Log for Calls through SIP provider (VoiceStick)
(I have defined an outbound rule to forward call to SIP line if # starts with 0 after removing 0 from it.)
11:00:31.953 CallConf::Rejected [CM103005] Call(13) is rejected: This line disallows incoming calls
11:00:31.953 Endpoint::findSource [CM010001] Line configuration does not allow identification of the source of this call. Check Advanced Options for Gateways and Providers and match a field to a correct value from the following: Contact IP: '65.XXX.XX.XXX'; From: '400'; To: '01XXXXXXXXX'; Rline: '01XXXXXXXXXX'; Contact: '400'
