Unable to make internal calls
Discussion in '3CX Phone System - General' started by djsuperstore, Feb 23, 2008.
  1. djsuperstore
    Feb 20, 2008
    25
    I have 2 snom 300 phones (ext 10 , 11) and 1 3cx softphone setup (ext 12).
    Neither snom phone can call each other. The snom phone can call the softphone ok but the softphone can not call either snom phone.
    Here is the log. I can not see why the error is Forbidden
    14:42:21.218 Call::Terminate [CM503008]: Call(165): Call is terminated
    14:42:21.187 Call::RouteFailed [CM503014]: Call(165): Attempt to reach [sip:11@192.168.1.15:5060] failed. Reason: Forbidden
    14:42:21.187 CallLeg::eek:nFailure [CM503003]: Call(165): Call to sip:11@192.168.1.15 has failed; Cause: 403 Use Proxy; from IP:192.168.1.102:2066
    14:42:21.062 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(165): Calling: Ext:11@[Dev:sip:11@192.168.1.102:2066;line=sis260ey]
    14:42:21.031 CallCtrl::eek:nIncomingCall [CM503001]: Call(165): Incoming call from Ext.12 to [sip:11@192.168.1.15:5060]
    14:42:14.140 Call::Terminate [CM503008]: Call(164): Call is terminated
    14:42:12.515 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(164): Calling: Ext:12@[Dev:sip:12@192.168.1.106:5070;rinstance=3338ae03723d5a6d]
    14:42:12.500 CallCtrl::eek:nIncomingCall [CM503001]: Call(164): Incoming call from Ext.11 to [sip:12@192.168.1.15;user=phone]
    14:42:06.265 Call::Terminate [CM503008]: Call(163): Call is terminated
    14:42:06.250 Call::RouteFailed [CM503014]: Call(163): Attempt to reach [sip:10@192.168.1.15;user=phone] failed. Reason: Forbidden
    14:42:06.250 CallLeg::eek:nFailure [CM503003]: Call(163): Call to sip:10@192.168.1.15 has failed; Cause: 403 Use Proxy; from IP:192.168.1.100:2069
    14:42:06.140 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(163): Calling: Ext:10@[Dev:sip:10@192.168.1.100:2069;line=mbzss3cj]
    14:42:06.093 CallCtrl::eek:nIncomingCall [CM503001]: Call(163): Incoming call from Ext.11 to [sip:10@192.168.1.15;user=phone]
    14:41:47.250 ExtnCfg::updateContact [CM504001]: Ext.11: new contact is registered. Contact(s): [sip:11@192.168.1.102:2066;line=sis260ey/11]
  2. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    You SNOM settings is not correct. http://www.3cx.com/sip-phones/snom.html
  3. djsuperstore
    Feb 20, 2008
    25
    Thanks for the reply. Any idea which setting is wrong. The page refers to the Snom 320, cant find one for the Snom 300. Are they the same?
    Thew only thing I have set up is the "Identity 1"
    Display Name : Shopdesk
    Account : 11
    Password : 11
    Registrar : 192.168.1.15
    Outbound Proxy : 192.168.1.15
    Authentication Username : 11
    Made sure that the profile is active also.
  4. igor.snezhko
    Jan 7, 2008
    668
    7
    Clear Outbound Proxy parameter. Dont put anything to it in the telephone settings page.
  5. djsuperstore
    Feb 20, 2008
    25
    I tried that and the snom display says "Not found" I'm just dialing "10"
    I also rebooted the phones each time
    15:41:48.046 Call::Terminate [CM503008]: Call(186): Call is terminated
    15:41:48.031 Call::RouteFailed [CM503014]: Call(186): Attempt to reach [sip:10@192.168.1.15;user=phone] failed. Reason: Forbidden
    15:41:48.031 CallLeg::eek:nFailure [CM503003]: Call(186): Call to sip:10@192.168.1.15 has failed; Cause: 403 Use Proxy; from IP:192.168.1.100:2075
    15:41:47.875 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(186): Calling: Ext:10@[Dev:sip:10@192.168.1.100:2075;line=7hdams3z]
    15:41:47.859 CallCtrl::eek:nIncomingCall [CM503001]: Call(186): Incoming call from Ext.11 to [sip:10@192.168.1.15;user=phone]
    15:41:37.187 ExtnCfg::updateContact [CM504001]: Ext.11: new contact is registered. Contact(s): [sip:11@192.168.1.102:2072;line=1ueiul2j/11]
    15:41:21.328 ExtnCfg::updateContact [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:10@192.168.1.100:2075;line=7hdams3z/10]
    15:41:14.390 ExtnCfg::updateContact [CM504002]: Ext.11: a contact is unregistered. Contact(s): []
    15:40:58.421 ExtnCfg::updateContact [CM504002]: Ext.10: a contact is unregistered. Contact(s): []
    15:40:33.296 Call::Terminate [CM503008]: Call(185): Call is terminated
  6. djsuperstore
    Feb 20, 2008
    25
    Added Verbose Logging For More Details
    17:11:20.218 Call::Terminate [CM503008]: Call(2): Call is terminated
    17:11:20.078 Call::RouteFailed [CM503014]: Call(2): Attempt to reach [sip:10@192.168.1.15;user=phone] failed. Reason: Forbidden
    17:11:20.078 CallLeg::eek:nFailure [CM503003]: Call(2): Call to sip:10@192.168.1.15 has failed; Cause: 403 Use Proxy; from IP:192.168.1.100:2057
    17:11:20.000 MediaServerReporting::SetRemoteParty [MS210006] C:2.2:Offer provided. Connection(by pass mode): 192.168.1.102:55732(55733)
    17:11:19.984 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(2): Calling: Ext:10@[Dev:sip:10@192.168.1.100:2057;line=at9dh5rf]
    17:11:19.984 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:10@192.168.1.15;user=phone]
    17:11:19.984 MediaServerReporting::SetRemoteParty [MS210000] C:2.1:Offer received. RTP connection: 192.168.1.102:55732(55733)
    17:11:19.968 CallLeg::setRemoteSdp Remote SDP is set for legC:2.1
    17:11:19.968 Extension::printEndpointInfo [CM505001]: Ext.11: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.1.30] Transport: [sip:192.168.1.15:5060]
    17:11:19.921 CallCtrl::eek:nIncomingCall [CM503001]: Call(2): Incoming call from Ext.11 to [sip:10@192.168.1.15;user=phone]
    17:11:19.921 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:10@192.168.1.15;user=phone SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.102:2057;branch=z9hG4bK-rsnowtf9orpq;rport=2057
    Max-Forwards: 70
    Contact: [sip:11@192.168.1.102:2057;line=6lmrzat5];flow-id=1
    To: [sip:10@192.168.1.15;user=phone]
    From: "Shopdesk"[sip:11@192.168.1.15];tag=j0faguswh4
    Call-ID: 3c26746f22b5-jki3whidlt9o
    CSeq: 2 INVITE
    Session-Expires: 3600;refresher=uas
    Min-SE: 90
    Accept: application/sdp
    Allow: INVITE, ACK, CANCEL, BYE, REFER, OPTIONS, NOTIFY, SUBSCRIBE, PRACK, MESSAGE, INFO
    Proxy-Authorization: Digest username="11",realm="3CXPhoneSystem",nonce="12848260279:ba3439bc2c71319bd58e17bda18b15cb",uri="sip:10@192.168.1.15;user=phone",response="3af498e8201d34b6570c730d285c58e9",algorithm=MD5
    Supported: timer, 100rel, replaces, callerid
    User-Agent: snom300/7.1.30
    Allow-Events: talk, hold, refer, call-info
    Content-Length: 0
    P-Key-Flags: keys="3"
    17:08:41.296 ListenConnect SL: connected fs01:0/PHPExtension_0 at [fs01]/PHPExtension_0
  7. igor.snezhko
    Jan 7, 2008
    668
    7
    Describe your network setup please.
  8. djsuperstore
    Feb 20, 2008
    25
    we have a windows 2003 server as a domain controller, 1 nic card at the moment. the 3cx is on the server. a vigor router running dhcp and everything connected with a switch. no firewalls are running internally. cant see what we are doing wrong.
  9. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    Which model draytek vigor is it?
    Stephen
  10. igor.snezhko
    Jan 7, 2008
    668
    7
    I would recommend to use separate PC with fresh installation of Windows XP Home and 3CX without any other sotfware. Because any falure of server hardware or software make your telephone system unavailable. I never combine telephony server with any other server because it must work 7x24.
  11. djsuperstore
    Feb 20, 2008
    25
    the router is a 2800vg
  12. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    With my 2800vg i had to change the port on the internal voice setup to somthing other than 5060 (i used 50600) as the draytek was taking all the voice traffic even though none of the voice setups were enabled.
    Stephen
  13. bluefox8080
    bluefox8080 New Member
    Oct 28, 2007
    181
    Assign you Snom Phone static IP addresses and try it again.
  14. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    Surley static IP addresses should be no differant from DCHP addresses.
    Stephen
  15. bluefox8080
    Oct 28, 2007
    181
    It should not make a difference.
    It does help to eliminate unknown variables though.
    As you said, the router does have its own VoIP functionality and DHCP might interact with that via UPnP.
  16. djsuperstore
    Feb 20, 2008
    25
    I will try setting static IP addresses in the morning. Strange thing is that a number of soft phones installed will all work. I also have a number set up from VoipUnlimited and I can dial in from a BT line and the soft phones all ring and can answer the call. 2 way conversation is fine. The Snom phones do not ring though.
    I can call the soft phone from The Snom phones and everything works fine there. I can not call the Snom phones from the soft phone (status says "Not Found")
    Not sure but looks like the Snom phones are not responding when asked to ring??
  17. igor.snezhko
    Jan 7, 2008
    668
    7
    Try to flash latest firmware to Snom
  18. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    DHCP and UPnP do not interact.
  19. djsuperstore
    Feb 20, 2008
    25
    I updated the flash on the Snom on Saturday but it didn't make any difference.
    If I understand things, if I call one Snom to the other the traffic goes directly between them and not through the 3cx software?
    I remember reading that I could dial the IP address of the onther phone and it should connect.
    I dialed 192*168*1*100 and pressed the tick. The display changed to 192.168.1.100 but no call connected.
  20. igor.snezhko
    Jan 7, 2008
    668
    7
    Check http://www.3cx.com/support/source-identification-err-2.html
    Check RTP protocol settings on Snom
