- Joined
- Aug 2, 2014
- Messages
- 30
- Reaction score
- 3
Hello everyone,
New to 3cx, but not new to IP PBX systems. Have been deploying Yeastar asterisk style boxes for the past year with little to no problems. The company I work for has decided to make the move to 3cx for it's VIP clients.
I love 3cx and how it seems to function right out of the box, however, I'm getting an odd error when trying to make outbound calls.
Explanation of network:
Broadsoft Switch in the Cloud > FIOS > Edgewater Router (which is acting as a registration SBC ) > 3CX server
Version: 12.5
Steps to reproduce the issue.
At 3cx Phone (windows client) dial external number and press call.
Receive error: Call Failed. Destination Not Found.
Checked the Server activity logs.
From what I can tell, error "604 Does not exist anywhere" is saying that the 7273755757 does not exist anywhere. Does that mean on the broadsoft switch or is that specifically on the 3CX server?
From what my googling of this error means, it's something to do with the remote party ID? I do know for this Broadsoft switch, for outbound calls, the "From User" needs to be the same as the user name for the trunk. I didn't see a place for me to set that anywhere.
Any suggestions?
Version: 12.5
Code:
12-Jan-2015 17:49:33.420 Leg L:9.1[Extn] is terminated: Cause: BYE from PBX
12-Jan-2015 17:49:33.370 [CM503020]: Call(C:9): Normal call termination. Call originator: Extn:102. Reason: Not found
12-Jan-2015 17:49:33.370 L:9.1[Extn] failed to reach Line:44922>>7273755757, reason Not Found
12-Jan-2015 17:49:33.370 Leg L:9.2[Line:44922>>7273755757] is terminated: Cause: 604 Does not exist anywhere/INVITE from 192.168.228.1:5060
12-Jan-2015 17:49:33.370 Call to T:Line:44922>>7273755757@[Dev:sip:[email protected]:5060] from L:9.1[Extn] failed, cause: Cause: 604 Does not exist anywhere/INVITE from 192.168.228.1:5060
12-Jan-2015 17:49:33.369 [CM503003]: Call(C:9): Call to <sip:[email protected]:5060> has failed; Cause: 604 Does not exist anywhere/INVITE from 192.168.228.1:5060
12-Jan-2015 17:49:33.219 [CM503025]: Call(C:9): Calling T:Line:44922>>7273755757@[Dev:sip:[email protected]:5060] for L:9.1[Extn]
12-Jan-2015 17:49:33.170 [CM503027]: Call(C:9): From: Extn:102 ("Jorge Lopez" <sip:[email protected]:5060>) to T:Line:44922>>7273755757@[Dev:sip:[email protected]:5060]
12-Jan-2015 17:49:33.170 [CM503004]: Call(C:9): Route 1: from L:9.1[Extn] to T:Line:44922>>7273755757@[Dev:sip:[email protected]:5060]
12-Jan-2015 17:49:33.170 Call(C:9): Call from Extn:102 to 7273755757 matches outbound rule 'Rule for SUNTELTEST3CX'
12-Jan-2015 17:49:33.169 [CM503001]: Call(C:9): Incoming call from Extn:102 to <sip:[email protected]:5060>
Any suggestions?
