Unable to make outbound calls on new 3CX 6.0 install
Discussion in '3CX Phone System - General' started by dbarney, Jul 17, 2008.
  1. dbarney
    May 14, 2008
    18
    I am trying out 3CX, and have configured my Polycom to my 3CX PBX. It shows in 3CX as online (green light). I have also setup InPhoneX as my SIP Provider for outbound calls, which also shows as successfully registering.
    I have created 2 outbound rules, (one with a dial extension of 9, the other with none). No matter what I do, no outbound call works.
    I have not configured inbound, as InPhoneX has yet to setup my DID.
    Here is what the server logs show:
    It then says the call was terminated.
    I am attempting to call my cell phone, and I just get a busy tone.
    Any suggestions? I hope I gave enough information to help narrow the problem down.
    Thanks!
  2. Henk
    Henk Member
    Nov 13, 2007
    250
    If your VoIP is not configured as yet, what are you planning to use for outbound calls?
    PSTN?
    VoIP?
    You do not need DID, if you have a VoIP provider.
    H.
  3. dbarney
    May 14, 2008
    18
    I stated I set up a SIP Prover InPhoneX. They are who outbound calls go through.
  4. dbarney
    May 14, 2008
    18
    Anyone have an idea as to what might be wrong? I am at a loss here...
    Thanks.
  5. dbarney
    May 14, 2008
    18
    I figured it out. After testing the 3cx Voip Client, I found that it was working fine. Furhter testing, found that i missed a number in my server ip of the polycom phone.
  6. justin
    Feb 20, 2008
    79
    Whoops :p
