Unable to make outbound calls on Sipgate Network
Discussion in '3CX Phone System - General' started by chwebb1, Jan 30, 2011.
  1. chwebb1
    Aug 16, 2010
    20
    I am using the VoIP Provider Sipgate.com for inbound calls, and it works great for that, but I'm trying to use it for some outbound calls as well. I have it set in the outbound routes, however, 3cx simply skips over that trunk and does not log any reason why. Does anyone know how to fix this?
    Thanks!
    10,375
    231
    The 3CX logs will probably show the reason why the calls are "skipping over" the trunk, set the log level to verbose, it may give additional information. Post a log of a call attempt ,if you want.
  3. chwebb1
    Aug 16, 2010
    20
    I tried to make the same call twice, and here's what I got (I've marked out personal information):
    23:15:21.008 [CM503008]: Call(2): Call is terminated
    23:15:18.571 [CM505003]: Provider:[Future9] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:71314470@192.168.0.17:5060]
    23:15:18.571 [CM503002]: Call(2): Alerting sip:71314470@outgoing.future-nine.com:5060
    23:15:15.696 Currently active calls - 1: [2]
    23:15:11.446 [CM503025]: Call(2): Calling VoIPline:1XXXXXXXXXX@(Ln.10006@Future9)@[Dev:sip:71314470@outgoing.future-nine.com:5060]
    23:15:11.430 [CM503003]: Call(2): Call to sip:1XXXXXXXXXX@sip.goandcall.com:5060 has failed; Cause: 407 Proxy Authentication Required; from IP:81.26.212.150:5060
    23:15:10.977 [CM503025]: Call(2): Calling VoIPline:1XXXXXXXXXX@(Ln.10014@XeloQ)@[Dev:sip:736039@sip.goandcall.com:5060]
    23:15:10.914 [CM503004]: Call(2): Route 3: VoIPline:1XXXXXXXXXX@(Ln.10006@Future9)@[Dev:sip:71314470@outgoing.future-nine.com:5060]
    23:15:10.899 [CM503017]: Call(2): Target is not registered: VoIPline:1XXXXXXXXXX dialed on (AnyLine@Sipgate - Chris)
    23:15:10.899 [CM303003]: There are no available outbound lines on gateway Sipgate - Chris at this time.
    23:15:10.899 [CM503004]: Call(2): Route 1: VoIPline:1XXXXXXXXXX@(Ln.10014@XeloQ)@[Dev:sip:736039@sip.goandcall.com:5060]
    23:15:10.899 [CM503010]: Making route(s) to <sip:XXXXXXX@192.168.0.4>
    23:15:10.883 [CM505001]: Ext.1000: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [LG-Nortel LIP 6830 v1.2.43sctd SN/00405AXXXXXX] PBX contact: [sip:1000@192.168.0.17:5060]
    23:15:10.852 [CM503001]: Call(2): Incoming call from Ext.1000 to <sip:XXXXXXX@192.168.0.4>
    23:15:06.524 [CM504004]: Registration succeeded for: 10007@Sipgate - Chris
    23:15:06.133 [CM504003]: Sent registration request for 10007@Sipgate - Chris
    23:15:03.430 [CM504004]: Registration succeeded for: 10007@Sipgate - Chris
    23:15:03.102 [CM504003]: Sent registration request for 10007@Sipgate - Chris
    23:14:55.461 Subscr. terminated for from 1000@192.168.0.4
    23:14:55.461 New SIP device is on-line: 1000; ip=192.168.0.18; contact=sip:1000@192.168.0.18:5060
    23:14:06.133 [CM503008]: Call(1): Call is terminated
    23:14:01.399 [CM505003]: Provider:[Future9] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:71314470@192.168.0.17:5060]
    23:14:01.399 [CM503002]: Call(1): Alerting sip:71314470@outgoing.future-nine.com:5060
    23:13:55.242 Subscr. terminated for from 1000@192.168.0.4
    23:13:55.242 New SIP device is on-line: 1000; ip=192.168.0.18; contact=sip:1000@192.168.0.18:5060
    23:13:54.102 [CM503025]: Call(1): Calling VoIPline:1XXXXXXXXXX@(Ln.10006@Future9)@[Dev:sip:71314470@outgoing.future-nine.com:5060]
    23:13:54.055 [CM503003]: Call(1): Call to sip:1XXXXXXXXXX@sip.goandcall.com:5060 has failed; Cause: 407 Proxy Authentication Required; from IP:81.26.212.150:5060
    23:13:53.008 [CM503025]: Call(1): Calling VoIPline:1XXXXXXXXXX@(Ln.10014@XeloQ)@[Dev:sip:736039@sip.goandcall.com:5060]
    23:13:52.321 [CM503004]: Call(1): Route 3: VoIPline:1XXXXXXXXXX@(Ln.10006@Future9)@[Dev:sip:71314470@outgoing.future-nine.com:5060]
    23:13:52.321 [CM503017]: Call(1): Target is not registered: VoIPline:1XXXXXXXXXX dialed on (AnyLine@Sipgate - Chris)
    23:13:52.321 [CM303003]: There are no available outbound lines on gateway Sipgate - Chris at this time.
    23:13:52.321 [CM503004]: Call(1): Route 1: VoIPline:1XXXXXXXXXX@(Ln.10014@XeloQ)@[Dev:sip:736039@sip.goandcall.com:5060]
    23:13:52.227 [CM503010]: Making route(s) to <sip:XXXXXXX@192.168.0.4>
    23:13:52.196 [CM505001]: Ext.1000: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [LG-Nortel LIP 6830 v1.2.43sctd SN/00405AXXXXXX] PBX contact: [sip:1000@192.168.0.17:5060]
    23:13:52.117 [CM503001]: Call(1): Incoming call from Ext.1000 to <sip:XXXXXXX@192.168.0.4>
    Why would it say that there are no available outbound lines?
    Thanks!
  4. chwebb1
    Aug 16, 2010
    20
    In case anyone else has this issue, I forgot to check the box "Allow outgoing calls on this line", which is found by clicking on the DID under VoIP Providers.You'll need to click the disclosure box next to your provider to see your DID/Port Identifier/External Number.
  5. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    looks as if 3CX is trying to route outgoing calls via outgoing.future-nine.com
    check the outbound rules and ensure sipgate is first in the route list.
