Unable to make Outbound Calls
Discussion in 'Windows' started by warm2day, Apr 27, 2009.
  1. warm2day
    Apr 27, 2009
    I have setup a test configuration of 3cx however I am unable to make an outbound call. Both the VOIP Trunk and the 2 extensions (3CX Softphone and SPA942) show as "Registered" and I receive a dial tone on either phone. However, when attempting to dial an outside number I get a fast busy sound although a call can be made from extension to extension. The system log shows a 404 error message when attempting to dial an outside number.
    VOIP provider is: Future-Nine
    VOIP line is configured to stip the leading digit (9) Number dialed: 9xxx-xxxx
    SPA942 configured to IP of 3CX server.
    ISP <> Public IP<> Cable Modem / Public IP <>Netgear FVS318 <> LAN IP (192.168.0.1) <> 3CX Server (192.168.0.2) <> SPA942 (192.168.0.3) <> 3CX Softphone on Thinkpad (192.168.0.3)
    I also have a working configuration with the following: ISP <> Public IP <> Cable Modem <> Public IP <>Linksys WRV200 <> LAN IP (10.1.10.2) <> Linksys SPA9000<> Linksys SPA 400 <> SPA 962 (Two IP Phones) This configuration is also using Future-Nine as a VOIP provider. In addition to the SPA9K PBX, the SPA400 provides access to a POTS Line and hosts Voice Mail. A user of either SPA962 dials a "9" plus number to access the VOIP porvider or dials "8" plus number to use the POTS line. Although it did take some time to configure the system, it is working, however I can not seem to get the 3CX system to make an outbound call following the suggested setup in the 3CX documentation or by reviewing simular problems on this forum. Any thoughts or suggestions would be most appreciated, because at this point I am stumped. I had hoped that the 3CX solution would be easier to impliment but so far it has been a rather frustrating exercise.
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    hello,
    just like this, do you have make outbound rules ?
    if it's not this send the call reports please.
  3. warm2day
    Apr 27, 2009
    Yes an Outboud Rule has been created. And I created a DID number rule. Unable to connect to 3CX. Calling DID gets email of F9 account.
    Below is the log file:
    Thanks, in advance, for any assistance.
    16:56:22.329 [CM503008]: Call(2): Call is terminated
    16:56:22.314 [CM503015]: Call(2): Attempt to reach <sip:98024348649@192.168.0.2> failed. Reason: Not Found
    16:56:22.314 [CM503014]: Call(2): No known route to target: <sip:98024348649@192.168.0.2>
    16:56:22.298 [CM503010]: Making route(s) to <sip:98024348649@192.168.0.2>
    16:56:22.283 [CM505001]: Ext.100: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-6.1.3(a)] Transport: [sip:192.168.0.2:5060]
    16:56:22.283 [CM503001]: Call(2): Incoming call from Ext.100 to <sip:98024348649@192.168.0.2>
    16:56:09.095 [CM503008]: Call(1): Call is terminated
    16:56:09.095 [CM503015]: Call(1): Attempt to reach <sip:94348649@192.168.0.2> failed. Reason: Not Found
    16:56:09.095 [CM503003]: Call(1): Call to sip:4348649@future-nine.com:5060 has failed; Cause: 404 Not Found; from IP:64.251.23.244:5060
    16:56:08.486 [CM503004]: Call(1): Calling: VoIPline:4348649@(Ln.10000@Future Nine)@[Dev:sip:900355@future-nine.com:5060]
    16:56:08.423 [CM503010]: Making route(s) to <sip:94348649@192.168.0.2>
    16:56:08.392 [CM505001]: Ext.100: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-6.1.3(a)] Transport: [sip:192.168.0.2:5060]
    16:56:08.392 [CM503001]: Call(1): Incoming call from Ext.100 to <sip:94348649@192.168.0.2>
    16:55:27.033 [CM504008]: Fax Service: registered as sip:888@192.168.0.2:5060 with contact sip:888@192.168.0.2:5100;user=phone
    16:54:32.845 [CM504001]: Ext.100: new contact is registered. Contact(s): [sip:100@192.168.0.3:5060/100]
    16:50:26.814 [CM504008]: Fax Service: registered as sip:888@192.168.0.2:5060 with contact sip:888@192.168.0.2:5100;user=phone
    16:45:42.611 [CM504001]: Ext.999: new contact is registered. Contact(s): [sip:999@127.0.0.1:40600;rinstance=13b8136d379db145/999]
    16:45:36.767 [CM504001]: Ext.*1: new contact is registered. Contact(s): [sip:*1@127.0.0.1:40000;rinstance=94b9f1f870fcf9c4/*1]
    16:45:36.736 [CM504001]: Ext.*0: new contact is registered. Contact(s): [sip:*0@127.0.0.1:40000;rinstance=7afc19fa891933c0/*0]
    16:45:32.861 IP(s) added:[192.168.0.2]
    16:45:16.343 [CM504008]: Fax Service: registered as sip:888@192.168.0.2:5060 with contact sip:888@192.168.0.2:5100;user=phone
    16:45:16.093 [CM112000] Media Server is connected
    16:45:15.890 [CM306003]: SIP IP:port mapping (75.149.136.187:5060) resolved by STUN server 75.101.138.128:3478 differs from the one (75.149.136.187:2416 resolved by STUN server 69.0.208.27
    16:45:15.828 [CM506002]: Resolved SIP external IP:port (75.149.136.187:5060) on Transport 192.168.0.2:5060
    16:45:15.625 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 75.101.138.128:3478 over Transport 192.168.0.2:5060
    16:45:13.593 [CM501007]: *** Started Calls Controller thread ***
    16:45:13.593 [CM501006]: Default Local IP address: [192.168.0.2]
    16:45:12.593 [CM501002]: Version: 7.1.6537.0
    16:45:12.593 [CM501001]: Start 3CX PhoneSystem Call Manager
    16:45:12.281 Unknown system [DBProvider] tries to connect!
    16:45:12.265 [CM501010]: License Info: Load Failed
  4. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    hello,
    there is an erro here :
    i must be 16:56:08.486 [CM503004]: Call(1): Calling: VoIPline:94348649@(Ln.10000@Future Nine)@[Dev:sip:900355@future-nine.com:5060]
    i suppose it's an error in your outbound rules. verify if you have enter 1 strip digit, if yes it must be 0.
  5. warm2day
    Apr 27, 2009
    Just a quick update; am able to make outbound calls now. It turned out to be an error in the login information and DID configuration. Will post more info later to provide assistance to other readers of the forum. Next project is to configure a gateway.
  6. bduke08021
    Jun 20, 2009
    34
    I am having the same problem.
    00:10:29.676 [CM503008]: Call(39): Call is terminated
    00:10:29.645 [CM503015]: Call(39): Attempt to reach <sip:6092544410@172.10.1.4:5060> failed. Reason: Not Found
    00:10:29.645 [CM503003]: Call(39): Call to sip:6092544410@127.0.0.1:6060 has failed; Cause: 404 Not Found; from IP:127.0.0.1:6060
    00:10:28.535 [CM503024]: Call(39): Calling PSTNline:6092544410@(Ln.10000@Skype)@[Dev:sip:10000@127.0.0.1:6060]
    00:10:28.535 [CM503004]: Call(39): Route 1: PSTNline:6092544410@(Ln.10000@Skype)@[Dev:sip:10000@127.0.0.1:6060]
    00:10:28.504 [CM503010]: Making route(s) to <sip:6092544410@172.10.1.4:5060>
    00:10:28.504 [CM505001]: Ext.1100: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 3.1.6288.0] Transport: [sip:172.10.1.4:5060]
    00:10:28.473 [CM503001]: Call(39): Incoming call from Ext.1100 to <sip:6092544410@172.10.1.4:5060>
  7. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    hello
    hhaha skype :) .
    do you have follow this intrcutions ? http://www.3cx.com/voip-gateways/skype.html
  8. bduke08021
    Jun 20, 2009
    34
    I figured it out, oyu must dial the country code, so i put it in the prepend.
