Daryle
- Joined
- May 16, 2018
- Messages
- 20
- Reaction score
- 1
I just replaced my local 3CX server with one provisioned by Google Cloud Platform with a static IP number. In 3CX-->SIP Trunks-->Flowroute-->Edit-->General, outbound proxy is set to the static IP #; Type of Authentication is set to "Do not require - IP Based; Authentication ID and Authentication Password are still set to what they were before the move to GCP (Registered/Account based).
All outbound rules are now set to prepend the Flowroute SIP account number to the route: 60#####8*1
In the Flowroute web console, Preferences-->Fraud Control is now set to "Outbound SIP Credentials (Disabled).
All phones, extensions, and the SIP trunk in 3CX show green but I can't make any outgoing calls. The Grandstream 1625 handset reports a "404 NOT FOUND" error.
The actual log entries in 3CX show the following are confirmed but I've obfuscated the Flowroute account number, number dialed, and the static IP number with hash (#) symbols for security reasons.
I would appreciate any insights anyone has.
12/16/2018 11:09:46 PM - Call to T:Line:10000>>60#####8*1403######9@[Dev:sip:60#####[email protected]:5060] from L:1.1[Extn:00] failed, cause: Cause: 404 User unknown./INVITE from 35.###.###.147:5060
12/16/2018 11:09:46 PM - [CM503003]: Call(C:1): Call to "Daryle Niedermayer" <sip:60#####8*1403######[email protected]:5060> has failed; Cause: 404 User unknown./INVITE from 35.###.###.147:5060
12/16/2018 11:09:46 PM - [CM102001]: Authentication failed for AuthFail Recv Req INVITE from 35.###.###.147:5060 tid=d2fc61600c165c34 Call-ID=O1htBeU4fSqS4HE0-7AEWw..:
INVITE sip:60#####8*1403######[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 35.###.###.147:5060;branch=z9hG4bK-524287-1---d2fc61600c165c34;rport=5060
Max-Forwards: 70
Contact: <sip:5876009669@35.###.###.147:5060>
To: "Daryle Niedermayer"<sip:60#####8*1403######[email protected]:5060>
From: "Daryle Niedermayer"<sip:[email protected]:5060>;tag=5105b226
Call-ID: O1htBeU4fSqS4HE0-7AEWw..
CSeq: 2 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE, UPDATE
Content-Type: application/sdp
Proxy-Authorization: Digest username="60#####8",realm="3CXPhoneSystem",nonce="414d53595c173daa55:c13b6a8a3d3658aab79709f88ece072c",uri="sip:60#####8*1403######[email protected]:5060",response="32333baaacb381e25082266d86d567b5",algorithm=MD5
Supported: replaces, timer
User-Agent: 3CXPhoneSystem 15.5.15502.6 (15502)
P-Asserted-Identity: "Atlas Solutions"<sip:[email protected]:5060>
Content-Length: 289
v=0
o=3cxPS 7356203206180864 32887308688556033 IN IP4 35.###.###.147
s=3cxPS Audio call
c=IN IP4 35.###.###.147
t=0 0
m=audio 9002 RTP/AVP 0 8 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=sendrecv
; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
12/16/2018 11:09:46 PM - [CM302002]: Authentication failed due to unidentified source of: SipReq: INVITE 60#####8*1403######[email protected]:5060 tid=d2fc61600c165c34 cseq=2 INVITE contact=5876009669@35.###.###.147:5060 / 2 from(wire)
Max-Forwards: 70
CSeq: 2 INVITE
Content-Length: 289
v=0
s=3cxPS Audio call
t=0 0
a=fmtp:18 annexb=no
a=sendrecv
