Unable to make outgoing calls
Discussion in '3CX Phone System - General' started by amlow, Sep 3, 2013.
  1. amlow
    Sep 3, 2013
    6
    I have install the 3CX Phone System for Windows which is replacing SPA9000
    and connected to our sip trunk provider(012smile).
    i am able to get incomimg calls perfect.
    but no outgoing calls outside of the company lan.
    in the debug log i can see error 408 -
    "[CM503003]: Call(25): Call to sip:0722001000@212.199.156.202:5060 has failed; Cause: 408 Request Timeout; interna
    The full log
    10:08:47.921
    [CM503020]: Normal call termination. Reason: No answer
    10:08:47.921
    [CM503016]: Call(25): Attempt to reach <sip:0722001000@10.100.103.2:5060> failed. Reason: No Answer
    10:08:47.921
    [CM503003]: Call(25): Call to sip:0722001000@212.199.156.202:5060 has failed; Cause: 408 Request Timeout; internal
    10:08:40.296
    Currently active calls - 1: [25]
    10:08:15.796
    [CM503025]: Call(25): Calling VoIPline:0722001000@(Ln.10000@012)@[Dev:sip:212.199.156.202:5060]
    10:08:15.781
    [MS210002] C:25.2:Offer provided. Connection(transcoding mode): 91.205.80.69:9044(9045)
    10:08:15.750
    [CM503004]: Call(25): Route 1: VoIPline:0722001000@(Ln.10000@012)@[Dev:sip:212.199.156.202:5060]
    10:08:15.750
    [CM503010]: Making route(s) to <sip:0722001000@10.100.103.2:5060>
    10:08:15.750
    [MS210000] C:25.1:Offer received. RTP connection: 10.100.103.105:40042(40043)
    10:08:15.734
    Remote SDP is set for legC:25.1
    10:08:15.734
    [CM505001]: Ext.102: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.26523.0] PBX contact: [sip:102@10.100.103.2:5060]
    10:08:15.734
    [CM503001]: Call(25): Incoming call from Ext.102 to <sip:0722001000@10.100.103.2:5060>
    10:08:15.734
    [CM500002]: Info on incoming INVITE:
    INVITE sip:0722001000@10.100.103.2:5060 SIP/2.0
    Via: SIP/2.0/UDP 10.100.103.105:53965;branch=z9hGfdgK-d845z-d1dsfsdfsdfsd4-1---d8754z-;rport=53965
    Max-Forwards: 70
    Contact: <sip:102@10.100.103.105:53965;rinstance=73036ffd7cfd1547>
    To: <sip:0722001000@10.100.103.2:5060>
    From: "0722721872"<sip:102@10.100.103.2:5060>;tag=295d7a47
    Call-ID: MDUxYjQ1MjIxODJSDDFSFSFE.
    CSeq: 2 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
    Proxy-Authorization: Digest username="102",realm="3CXPhoneSystem",nonce="414d345345341bdf13:5c82736a3454534534543543a",uri="sip:0722001000@10.100.103.2:5060",response="csdfs769796fsd",algorithm=MD5
    Supported: replaces
    User-Agent: 3CXPhone 6.0.26523.0
    Content-Length: 0
    Any help will be greatly appreciated
  2. Paddyd
    Jul 19, 2013
    9
    From the above line I would be looking to a firewall issue. Sip messages are carried TCP but the RTP which houses the voices is a UDP port. Could it be UDP is being locked.
    There is a firewall checker built into 3CX. It will stop all calls while it runs but I has helped me in the past
  3. amlow
    Sep 3, 2013
    6
    hey Paddyd
    thank you for your reply, i was thinking on this direction
    i will test and post the results.
  4. amlow
    Sep 3, 2013
    6
    i did all port forwarding correctly and even test if from remote ok.
    however when trying to to firewall check i get
    CX Firewall Checker, v1.0. Copyright (C) 3CX Ltd. All rights reserved. <12:48:05>: Phase 1, checking servers connection, please wait... <12:48:05>: Stun Checker service is reachable. Phase 1 check passed. <12:48:05>: Phase 2a, Check Port Forwarding to UDP SIP port, please wait... <12:48:05>: UDP SIP Port is set to 5060. NO RESPONSE received. Phase 2a check FAILED. Application exit code is -2
    any idea ?
  5. tarmeeb
    Aug 28, 2013
    19
    I have the exact case
    For all outgoing voice/calls using Outside Office Lan, and Tunnel service, it is not working
    I have ran the firewall checker and all is working, I have forwarded all ports
    What is going on?
  6. leejor
    10,362
    227
    Tarmeeb
    Unless you are offering a solution, or suggestion, you should be starting a new post, not hijacking an existing one. The cause of your issue may be completely different, simply a similar problem.
    You have also failed to provide any information about your installation, and the exact problems you are having.
  7. amlow
    Sep 3, 2013
    6
    I'm now able to pass all firewall test OK but still getting error
    08:49:53.062
    [CM503016]: Call(12): Attempt to reach <sip:0722001000@10.100.103.2:5060> failed. Reason: No Answer
    08:49:53.062
    [CM503003]: Call(12): Call to sip:0722001000@212.199.156.202:5060 has failed; Cause: 408 Request Timeout; internal
    any idea?
  8. leejor
    10,362
    227
    What make/model router are you using? Has that changed since you were using the 9000? There may be a setting that requires changing.
  9. amlow
    Sep 3, 2013
    6
    I'm using Linksys RV042 and spa922 phones, i have configure the port forwarding manually according to 3cx guidelines.
    http://www.3cx.com/sip-phones/linksys-spa-921/
    Do you think it is router related issue ?
    i have also tried TP-LINK router but same error.
  10. leejor
    10,362
    227
    It seems that you may not be the only one having an issue with that particular router. It may come down to the firmware, or options. At the bottom of these posts there is a link that may lead to some answers for you.
    http://community.linksys.com/t5/Wired-Routers/RV042-SIP-Registration-problems-VOIP/td-p/214570
    If you've tried another router, then this may be a dead end.
  11. amlow
    Sep 3, 2013
    6
    Hey leejor,
    Thank you for your help, do yo have any recommendation on smb router that works
    well with 3cx ?
  12. tarmeeb
    Aug 28, 2013
    19
    @Leejer
    I don't see any hijacking or up normal usage, these are public forums,no one dictates what to be done, especially if no rules are crossed, and people discuss things over internet forums. and it is very normal to say something such as:" Yeah I am facing the same issue too...."
    I did indeed post the information about my network in the other thread.
    Your attitude and input are no longer appreciated.
    Thank you
  13. leejor
    10,362
    227
    I find the the simpler the router, the fewer the problems. That said, most businesses are not going to be happy with a basic, residential router, security option limitations , being a big factor.
    I personally use a couple of D-Link DIR-615 with DD-WRT VPN firmware. It works fine for my situation, but probably wouldn't be acceptable in many installations. If you go back through the forum, there have been a number of people asking for router recommendations, along with some suggestions. It may also depend on how much you want, or are willing to spend.
    This might be of help...
    http://www.3cx.com/blog/voip-howto/router-firewall-features-requirements/
