Unable to place a call
Discussion in '3CX Phone System - General' started by robertofmlx, Jan 14, 2014.
  1. robertofmlx
    Jan 14, 2014
    I have a phone in our network that is unable to place a call. The client is a regular phone connected to a Linksys SPA2102. There are two phone on that box and line 2 works fine, line 1 fails when placing calls. On the other hand, line 1 is able to register just fine and can receive calls. Out of my whits!
    I looked at the server and it looks like a proxy-authentication header is missing when line 1 places a call, but I have checked both client and server sides and both line 1 and 2 are the same (other than some basic info). Can someone give me a clue?
    As you can see, the call is internally from extension to extension in this case. Needless to say calls to external #s fail too.
    TIA
    13:14:11.309 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:117@192.168.123.253 SIP/2.0
    Via: SIP/2.0/UDP 192.168.123.11:5060;branch=z9hG4bK-5b2cfca1
    Max-Forwards: 70
    Contact: "Anonymous"<sip:138@192.168.123.11:5060>
    To: <sip:117@192.168.123.253>
    From: "Anonymous"<sip:anonymous@localhost>;tag=f992913e6f2bf999o0
    Call-ID: d08441e2-ef536145@localhost
    CSeq: 101 INVITE
    Expires: 240
    Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
    Supported: x-sipura
    User-Agent: Linksys/SPA2102-3.3.6
    Content-Length: 0
    Remote-Party-ID: Real UserName <sip:138@192.168.123.253>;screen=yes;privacy=full;party=calling
    10,848
    299
    Are you certain that the second line has port 5061 (or at least NOT 5060) assigned?
  3. robertofmlx
    Jan 14, 2014
    Yes, the two lines go against 5061 (in fact, I changed line 1 from 5060 to 5061 because line 2 worked). The weird thing is that all the other boxes go to 5060. But why would Line 2 work?? I'll run a small test on this.
  4. leejor
    10,848
    299
    When you have a SIP "box" (this could be a Gateway or an ATA) with two or more devices/lines/trunks inside, it is common to address each with its own port number as the "box" has only one IP. 3CX sees each as unique as it will register as the IP + port number. I'm not sure what else you may have changed on the ATA, but, if you have made a number of changes, and didn't keep track, you may want to consider a 'factory" reset and fresh start.
    With the 2102, from a factory fresh start, the only differences between the two lines will be the extension number/name and password. (that assumes you have left the ports alone and line 1 is at 5060 and line 2 is at 5061) The dialplan can be cut and pasted from the working line to the other. RTP Packet Size can be changed to 0.020 and you may want to consider giving the device a fixed IP, if you haven't already. NTP server(s) can be datafilled to provide the correct time/date on CID of incoming calls.
    That should give you a basic working ATA. Other settings may require changes for additional features, or regional differences as the defaults (depending on the version) are generally for north America.
  5. robertofmlx
    Jan 14, 2014
    Thanks for the explanation Leejor... good to learn something new. As you might guess, I'm sort of a part time IT "department" at my company. I'm back at it!
    I changed line 1 to 5060 and line 2 remained on 5061. I still have the same problems.
    Not sure if this helps, but the bad line (line 1) is able to receive calls, but not place them. Also, on the server side things look fine. I'm placing the good (x140) and bad (x138) line invites below to see if you can spot anything obvious. One difference is that the call-id/from/call-id revolved around anonymous and localhost. Could that be the problem? How do I change that?
    Good phone to x117
    12:40:54.045 [CM500002]: Info on incoming INVITE:
    Via: SIP/2.0/UDP 192.168.123.11:5060;branch=z9hG4bK-2ad45411
    Max-Forwards: 70
    Contact: "John Durian"<sip:140@192.168.123.11:5060>
    From: "John Durian"<sip:140@192.168.123.253>;tag=6236d3c25d0e4cc5o1
    Call-ID: f0e7d946-74836511@192.168.123.11
    CSeq: 102 INVITE
    Expires: 240
    Proxy-Authorization: Digest username="140",realm="3CXPhoneSystem",nonce="414d535c08e9fc2584:f2c916a593034bb48e5109cbed046a9c",uri="sip:117@192.168.123.253",algorithm=MD5,response="212b43a9dc9d800ec20fa8aeb9592577"
    Supported: x-sipura
    Content-Length: 0
    Remote-Party-ID: John Durian <sip:140@192.168.123.253>;screen=yes;party=calling
    Bad phone to x117
    12:48:43.170 [CM500002]: Info on incoming INVITE:
    Via: SIP/2.0/UDP 192.168.123.11:5060;branch=z9hG4bK-c02e21f5
    Max-Forwards: 70
    From: "Anonymous"<sip:anonymous@localhost>;tag=285c711531feeff4o0
    Call-ID: 5545cc69-757b2cb0@localhost
    CSeq: 102 INVITE
    Expires: 240
    Proxy-Authorization: Digest username="138",realm="3CXPhoneSystem",nonce="414d535c08e9fdfb63:33f4762c7273d43a808872e1fe580e02",uri="sip:117@192.168.123.253",algorithm=MD5,response="ac1988d19a8db126e22e72a5407b9877"
    Supported: x-sipura
    Content-Length: 0
    Remote-Party-ID: Mi Johnson <sip:138@192.168.123.253>;screen=yes;privacy=full;party=calling
    12:48:43.045 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    Via: SIP/2.0/UDP 192.168.123.11:5060;branch=z9hG4bK-190e0859
    Max-Forwards: 70
    CSeq: 101 INVITE
    Expires: 240
    Supported: x-sipura
    Content-Length: 0
    12:48:43.045 [CM302001]: Authorization system can not identify source of: SipReq: INVITE 117@192.168.123.253 tid=-190e0859 cseq=INVITE contact=138@192.168.123.11:5060 / 101 from(wire)
  6. leejor
    10,848
    299
    I suspect that there is still something amiss in the settings for Line 2
    This line, in the successful call should look the same as a call from line 2 with the exception of the highlighted items. The one that really concerns me is the port number. it should be showing as 5061.
    If you power down the ATA, then re-power and check the 3Cx log, does it show both extensions registering correctly? The extension numbers should be there along with the same IP but each using a different port.
    I'm not certain if some other features have been modified on the ATA and that is causing the issue.
    You may want to consider a factory reset, and start from scratch, this time only changing the server name, extension number(s) and password(s), to start with. Or, you can post the Line 2 settings.
  7. robertofmlx
    Jan 14, 2014
    Got it! I'm back at this... and finally discovered the difference
    This is what I found to be different on the bad line:
    Block CID Setting = Yes
    CID Setting = No
    They were the opposite on the other line. Not sure why these would affect placing a call?
