Unable to Receive Calls on Polycom Soundstation IP7000
Discussion in 'Windows' started by semtex65, Apr 19, 2013.
  1. semtex65
    Feb 23, 2012
    18
    Hi Guys,
    As the title would suggest, I'm having issues with a Polycom Soundstation IP7000 receiving incoming calls, be it on our internal network, or external. Outgoing calls work flawlessly. When calling in from another extension in the office (Cisco 7940) I get 'Re-Order' and an engaged tone.
    Interestingly, if an outgoing call on the Polycom is taking place and you then try to ring it then you will hear a normal ringing tone.
    Below is an extract from the Activity Log, with a Cisco 7940 (ext 102) trying to call the Polycom (ext 114).
    Code:
    09:51:49.628  [CM503016]: Call(4627): Attempt to reach <sip:114@192.168.51.100> failed. Reason: Not Found
    09:51:49.628  [todo] Call(4627): Can not call sip:114@192.168.51.21:5060: there's no free SLA appearance
    09:51:49.627  Failed to acquire SLA slot for DN 114; TODO: Do proper message
    09:51:49.584  [CM503004]: Call(4627): Route 1: Ext:Ext.114@[Dev:sip:114@192.168.51.21:5060]
    09:51:49.583  [CM503010]: Making route(s) to <sip:114@192.168.51.100>
    09:51:49.582  [CM505001]: Ext.102: Device info: Device Identified: [Man: Cisco;Mod: 7940;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco-CP7940G/8.0] PBX contact: [sip:102@192.168.51.100:5060]
    Can anyone shed any light on this?
    Cheers Muchly
  2. BoRiZkamn
    Aug 20, 2011
    deftoon
  3. semtex65
    Feb 23, 2012
    18
    Re: deftoon
    Anything helpful to contribute??
