Unable to register D-Link DPH-540 IP Phone
Discussion in '3CX Phone System - General' started by fischershaw, Jan 12, 2007.
  1. fischershaw
    Jan 3, 2007
    16
    Phone loops forever trying to register and being refused, just like the D-Link VoIP Gateway. 3CX appears to think the nonce used by the phone is stale, even though it just received it and replied immediately.
    Repro:
    Create extension
    Number = 10
    Id = 10
    Password = 666
    On DPH
    Edit the Default SIP account
    Phone Number = 10
    Auth ID = 10
    Auth Password = 666
    SIP Domain = 192.168.1.1
    Proxy Address = 192.168.1.1
    No change to Advanced settings
    Message exchange follows:
    REGISTER sip:192.168.1.1 SIP/2.0
    Max-Forwards: 70
    Content-Length: 0
    Via: SIP/2.0/UDP 192.168.2.11:5060;branch=z9hG4bK43dabe787
    Call-ID: 71d90c5564bf63e2d4a9541a4f0e3fcf@192.168.2.11
    To: 10 <sip:10@192.168.1.1>
    CSeq: 1253342995 REGISTER
    Contact: 10 <sip:10@192.168.2.11:5060>;expires=3600
    Allow: NOTIFY, REFER, OPTIONS, INVITE, ACK, CANCEL, BYE
    User-Agent: Callctrl/1.6.0.0 MxSF/v3.5.3.4
    Max-Forwards: 70
    Content-Length: 0
    SIP/2.0 407 Proxy Authentication Required
    Proxy-Authenticate: Digest nonce="12813115818:e875932a2df2037ca1049bd765a80c26",algorithm=MD5,realm="3CXPhoneSystem"
    To: "10"<sip:10@192.168.1.1>;tag=6a46336b
    Content-Length: 0
    Content-Length: 0
    Max-Forwards: 70
    Content-Length: 0
    Via: SIP/2.0/UDP 192.168.2.11:5060;branch=z9hG4bKe7855201e
    CSeq: 1253342996 REGISTER
    Proxy-Authorization:Digest response="1d73dfedc9691e5a3a7282b025aba9c5",username="10",realm="3CXPhoneSystem",nonce="12813115818:e875932a2df2037ca1049bd765a80c26",algorithm=MD5,uri="sip:192.168.1.1"
    Max-Forwards: 70
    Content-Length: 0
    Proxy-Authenticate: Digest nonce="12813115818:e875932a2df2037ca1049bd765a80c26",algorithm=MD5,realm="192.168.1.1",stale=true
    To: "10"<sip:10@192.168.1.1>;tag=0617a41e
    Content-Length: 0
    Content-Length: 0
    The same exchange continues forever.
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,004
    308
    Its based you post the server status log instead, only then can we see why the registration is being refused
  3. fischershaw
    Jan 3, 2007
    16
    10:43:24.125 ??: SL: connected redfish:0/PHPExtension_0 at [redfish]/PHPExtension_0
    10:43:16.000 AuthMgr::eek:nAuthSuccess: Extension "FischerShaw_Main"<sip:89714@192.168.1.1:5060> has been registered successfully
    10:42:51.984 AuthMgr::eek:nAuthSuccess: Extension "FischerShaw_Unused"<sip:80000@192.168.1.1:5060> has been registered successfully
    10:42:51.984 AuthMgr::eek:nAuthSuccess: Extension "FischerShaw_Gate"<sip:80001@192.168.1.1:5060> has been registered successfully
    10:42:51.875 AuthMgr::eek:nAuthSuccess: Extension "FischerShaw_Fax"<sip:89503@192.168.1.1:5060> has been registered successfully
    10:42:51.875 AuthMgr::eek:nAuthSuccess: Extension "FischerShaw_Main"<sip:89714@192.168.1.1:5060> has been registered successfully
    10:42:51.765 Registrar::eek:nFailure: Registration failure: <sip:227151@207.229.110.25> for sip:227151@207.229.110.25
    10:40:32.156 MediaServerConnected: Media Server is connected
    10:40:32.156 ??: SL: connected redfish:0/MediaServer at [redfish]/MediaServer
    10:40:25.203 SessionMgr::thread: ** Entering Main Loop **
    10:40:25.203 SessionMgr::run: ** Start Session Manager **
    10:40:25.187 SessionMgr::run: ** Initialize Status Monitor **
    10:40:25.140 LineImpl::update: Line: register line 227151
    10:40:24.953 DBA: ** Database connection Ok **
    10:40:24.921 SessionMgr::run: ** Initialize Lines Manager **
    10:40:24.921 SessionMgr::run: STUN resolved external IP: 207.229.110.25
    10:40:24.765 SessionMgr::run: ** Initialize Client Authentication **
    10:40:24.765 SessionMgr::run: ** Initialize Server Authentication **
    10:40:24.765 SessionMgr::run: ** Initialize DUM **
    10:40:24.281 SessionMgr::run: ** Adding transports **
    10:40:24.265 SessionMgr::run: Version: 2.0.913.0
