Unable to register from outside local LAN
Discussion in '3CX Phone System - General' started by daver56, Jun 29, 2011.
  1. daver56
    Jun 21, 2011
    5
    I have the free version of 3CX (for testing) ver 10, and to test, I am using 3CX forIPhone and 3CX VOIP Phone. On the local LAN everything works fine. When outside the local LAN I use the External Server option and enter the URL that points to my home DSL where the 3CX system resides. I have verified that the URL is correct and is pointing to my public IP, I have opened ports 5060, 5090, and 9000-9009 9000-9009 is setup in server also). The ports have been verified as open by using an external port status tool. The IPhone app and 3CX VOIP Phone will not register when away from the LAN. I get a authentication failure. I check the logs in the 3CX server and it shows "Credentials don't match, Check that authorization-ID and password match the ones in extension settings". These are the same credentials that I am using when on the local LAN. Can anyone give me any help on how to fix this issue. I feel there must be something simple I am missing.
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Open the extension that you wish to be able to connect remotely and click the other tab
    Make sure the box “Disallow use of extension outside the LAN” is not ticked
  3. daver56
    Jun 21, 2011
    5
    David,
    Thanks for the info. I thought I had checked all the settings looking for something like that. I am registering my external extensions now. Got a few more issues to work through, but that helps alot. Thanks again
    Dave
  4. davidbenwell
    Apr 27, 2010
    704
    No Worries
