unable to register voip provider
Discussion in '3CX Phone System - General' started by aguilar, Dec 26, 2007.
  1. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    hello
    i am not able to register 5 voip lines with my provider with other provider i can register but the call is for just 10 seconds (both providers works fine in version 3)
    i installed the last version 5.0.3752.0 and restored my version 3 backup and tried also to delete and create again one line but the problem still the same
    i am running a server 2003 box (clean install) with opened required ports
    thanks in advance
  2. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Does the firewall test in v5 report success?
  3. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    yes it does The firewall test passed with warnings. The port number was changed but the message said that it should not be a problem.
  4. silentfun
    silentfun Member
    Dec 11, 2006
    364
    on what system and with what tipe of network settings you use the pbx
    please specify
    is ita public ip?
    is the default gateway on same subnet ?
    for ex. 192.168.178.100
    def, gate way 192.168.178.1 ?
    the provider you use
    perhaps some of the log
  5. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    sure, its running in a w2003 server (clean install), i use a fixed IP, the network is compoused with 10 computers running in the same net (192.168.1.88) the defaul gateway is 192.168.1.254, the provider is a company of AT&T, my second provider is working fine, this lines work ok in version 3 and in a beta version also
    please let me know to where may i send the logs
    best regards and GREAT 2008
  6. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    follow log
    12:30:31.125 LineMgr::eek:nRegUpdAor Unregistered line: L:10005(89959171)
    12:30:31.062 LineMgr::eek:nRegUpdAor Unregistered line: L:10003(5589959162)
    12:30:30.750 LineMgr::eek:nRegUpdAor Unregistered line: L:10004(5589959129)
    12:30:30.562 LineMgr::eek:nRegUpdAor Unregistered line: L:10007(89959117)
    12:30:30.250 LineMgr::eek:nRegUpdAor Unregistered line: L:10002(50252312)
    12:30:30.250 ClientRegs::eek:nRequestRetry Registration attempt for L:10005(89959171) is scheduled in 60 sec.
    12:30:30.250 ClientRegs::eek:nRequestRetry Registration attempt for L:10003(5589959162) is scheduled in 60 sec.
    12:30:30.250 ClientRegs::eek:nRequestRetry Registration attempt for L:10004(5589959129) is scheduled in 60 sec.
    12:30:30.250 ClientRegs::eek:nRequestRetry Registration attempt for L:10007(89959117) is scheduled in 60 sec.
    12:30:30.250 ClientRegs::eek:nRequestRetry Registration attempt for L:10002(50252312) is scheduled in 60 sec.
    12:30:17.109 ListenConnect SL: connected aa33s:0/PHPExtension_0 at [aa33s]/PHPExtension_0
    12:29:19.015 LineMgr::eek:nRegUpdAor Unregistered line: L:10005(89959171)
    12:29:18.703 LineMgr::eek:nRegUpdAor Unregistered line: L:10003(5589959162)
    12:29:18.390 LineMgr::eek:nRegUpdAor Unregistered line: L:10004(5589959129)
    12:29:18.078 LineMgr::eek:nRegUpdAor Unregistered line: L:10007(89959117)
    12:29:17.765 LineMgr::eek:nRegUpdAor Unregistered line: L:10002(50252312)
    12:29:17.765 ClientRegs::eek:nRequestRetry Registration attempt for L:10005(89959171) is scheduled in 40 sec.
    12:29:17.765 ClientRegs::eek:nRequestRetry Registration attempt for L:10003(5589959162) is scheduled in 40 sec.
    12:29:17.765 ClientRegs::eek:nRequestRetry Registration attempt for L:10004(5589959129) is scheduled in 40 sec.
    12:29:17.765 ClientRegs::eek:nRequestRetry Registration attempt for L:10007(89959117) is scheduled in 40 sec.
    12:29:17.765 ClientRegs::eek:nRequestRetry Registration attempt for L:10002(50252312) is scheduled in 40 sec.
    12:28:41.359 LineMgr::eek:nRegUpdAor Registered line: L:10000(spa3102)
    12:28:39.046 ExtnCfg::updateContact [CM504001]: Ext.104: new contact is registered. Contact(s): [sip:104@192.168.1.177:5060/104]
    12:28:34.500 ExtnCfg::updateContact [CM504001]: Ext.103: new contact is registered. Contact(s): [sip:103@192.168.1.75:5060/103]
    12:28:31.109 ExtnCfg::updateContact [CM504001]: Ext.110: new contact is registered. Contact(s): [sip:110@192.168.1.80:5060/110]
    12:28:25.328 LineMgr::eek:nRegUpdAor Unregistered line: L:10005(89959171)
    12:28:25.328 LineMgr::eek:nRegUpdAor Unregistered line: L:10003(5589959162)
    12:28:25.312 LineMgr::eek:nRegUpdAor Unregistered line: L:10004(5589959129)
    12:28:25.312 LineMgr::eek:nRegUpdAor Unregistered line: L:10007(89959117)
    12:28:25.312 ClientRegs::eek:nRequestRetry Registration attempt for L:10005(89959171) is scheduled in 20 sec.
    12:28:25.203 LineMgr::eek:nRegUpdAor Unregistered line: L:10002(50252312)
    12:28:25.203 ClientRegs::eek:nRequestRetry Registration attempt for L:10003(5589959162) is scheduled in 20 sec.
    12:28:25.203 ClientRegs::eek:nRequestRetry Registration attempt for L:10004(5589959129) is scheduled in 20 sec.
    12:28:25.203 ClientRegs::eek:nRequestRetry Registration attempt for L:10007(89959117) is scheduled in 20 sec.
    12:28:25.203 ClientRegs::eek:nRequestRetry Registration attempt for L:10002(50252312) is scheduled in 20 sec.
    12:28:15.203 ExtnCfg::updateContact [CM504001]: Ext.109: new contact is registered. Contact(s): [sip:109@192.168.1.66:5060/109]
    12:28:14.843 ExtnCfg::updateContact [CM504001]: Ext.108: new contact is registered. Contact(s): [sip:108@192.168.1.66:5060/108]
    12:28:04.937 ExtnCfg::updateContact [CM504001]: Ext.101: new contact is registered. Contact(s): [sip:101@192.168.1.80:5060/101]
    12:27:53.390 LineMgr::eek:nRegUpdAor Registered line: L:10001(mcm)
    12:27:53.390 ClientRegs::eek:nSuccess [CM504004]: Registration succeeded for: 10001@mcm
    12:27:53.312 LineMgr::eek:nRegUpdAor Registered line: L:10001(mcm)
    12:27:53.203 ClientRegs::Register [CM504003]: Sent registration request for 10005@89959171
    12:27:53.203 ClientRegs::Register [CM504003]: Sent registration request for 10003@5589959162
    12:27:53.203 ClientRegs::Register [CM504003]: Sent registration request for 10004@5589959129
    12:27:53.125 ClientRegs::Register [CM504003]: Sent registration request for 10007@89959117
    12:27:53.093 ClientRegs::Register [CM504003]: Sent registration request for 10001@mcm
    12:27:53.093 ClientRegs::eek:nSuccess [CM504004]: Registration succeeded for: 10001@mcm
    12:27:53.031 ClientRegs::Register [CM504003]: Sent registration request for 10002@50252312
    12:27:52.593 ClientRegs::Register [CM504003]: Sent registration request for 10003@5589959162
    12:27:52.468 ClientRegs::Register [CM504003]: Sent registration request for 10001@mcm
    12:27:52.359 ClientRegs::Register [CM504003]: Sent registration request for 10002@50252312
    12:27:52.281 ClientRegs::Register [CM504003]: Sent registration request for 10007@89959117
    12:27:52.156 ClientRegs::Register [CM504003]: Sent registration request for 10004@5589959129
    12:27:51.984 ClientRegs::Register [CM504003]: Sent registration request for 10005@89959171
    12:27:51.640 StunClient::process [CM506002]: Resolved SIP external IP:port (201.136.2.199:5060) on Transport 192.168.1.88:5060
    12:27:51.546 StunClient::eek:nInitTests [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 64.69.76.23:3478 over Transport 192.168.1.88:5060
    12:27:51.359 CallMgr::eek:nAddIPs IP(s) added:[192.168.1.88]
    12:27:47.406 ExtnCfg::updateContact [CM504001]: Ext.111: new contact is registered. Contact(s): [sip:111@192.168.1.85:5060/111]
    12:27:45.843 ExtnCfg::updateContact [CM504001]: Ext.102: new contact is registered. Contact(s): [sip:102@192.168.1.82:5061/102]
    12:27:45.484 ExtnCfg::updateContact [CM504001]: Ext.106: new contact is registered. Contact(s): [sip:106@192.168.1.82:5060/106]
    12:27:44.890 ExtnCfg::updateContact [CM504001]: Ext.107: new contact is registered. Contact(s): [sip:107@192.168.1.78:5060/107]
    12:27:44.406 ExtnCfg::updateContact [CM504001]: Ext.105: new contact is registered. Contact(s): [sip:105@192.168.1.78:5060/105]
    12:27:43.359 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:888@3CXPhoneSystem with contact sip:888@192.168.1.88:5100;user=phone
    12:27:43.015 ListenConnect SL: connected aa33s:0/VoiceBoxManagerService at [aa33s]/VoiceBoxManagerService
    12:27:42.718 MediaServerConnected [CM112000] Media Server is connected
    12:27:42.718 ListenConnect SL: connected aa33s:0/MediaServer at [aa33s]/MediaServer
    12:27:42.093 IVRConnected [CM501004]: Connected: IVR Service
    12:27:42.093 ListenConnect SL: connected aa33s:5483/IVRServer at [aa33s]/IVRServer
    12:27:41.484 DBA [CM501003]: Connected: Database
    12:27:41.453 CallMgr::findLocalIPs [CM501006]: Default Local IP address: [192.168.1.88]
    12:27:41.453 CallCtrl::thread [CM501007]: *** Started Calls Controller thread ***
    12:27:41.328 CallMgr::Initialize [CM501002]: Version: 5.0.3752.0
    12:27:41.328 CallMgr::Initialize [CM501001]: Start 3CX PhoneSystem Call Manager
    12:27:41.312 LoadLicenceInfo [CM501009]: License Info: Loaded Succeeded
    best regards
  7. BAGLIETTODAVID
    Aug 22, 2007
    VOIP not working
    I have the same problem since updating to version 5 I have been keeping an eye on fixes and so for no luck. I have also done a clean install. My voip is with sipgate all I keep getting is the following
    22:36:06.062 Call::RouteFailed [CM503014]: Call(11): Attempt to reach [sip:01268******@192.168.1.2:5060] failed. Reason: Not Registered
    When I test the ports I get 90% of the ports working and when I retest it again i still only get about 90% working but diffrent ports.
  8. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    hi all
    in version 3648 works fine also
    regards
  9. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    Try this:
    in Lines >> Manager >> Manage Gateways & Providers >> Your Voip Provider >> Registration Settings
    "Which IP to use in 'Contact' field for registration:"
    Choose 'Specified IP' xxx.xxx.xxx.xxx:5060 (instead of External:Stun resolved) replace xxx's with your voip providers IP address
    Your telling 3CX what Ip to use to access your provider instead of having STUN try to figure it out.
  10. Henk
    Henk Member
    Nov 13, 2007
    250
    The full domain name should work aswell.
    Keep in mind that if the IP is changed you have to fix it again.
    Try to get the SIP server name from your VoIP provider, STUN is needed when you make calls and have NAT requirements.
    H.
  11. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    hi all
    Archie sent me this:
    There's a quick fix for your issue: edit 3CXPhoneSystem.ini file, in [Network] section add following string:
    localSubnets = 169.254.0.0/16,172.16.0.0/12,192.168.0.0/16
    now all my lines are working properly
    best regards and thanks
