Unable to Register with Skype Connect
Discussion in '3CX Phone System - General' started by BobD, Apr 25, 2011.
  1. BobD
    Apr 25, 2011
    27
    Newbie here. I'm trying to connect Skype Connect as VoIP Provider but it's failing with message:
    Did a lookup and found sip.skype.com is [63.209.144.201]
    I've run the Firewall Checker and everything passes without any warnings / errors.
    Bob
    11,293
    361
    You've double checked your password?
  3. BobD
    Apr 25, 2011
    27
    :oops:
    I'm thinking to myself -- I copied / pasted from the Skype web site -- it HAS to be the same!
    The copy picked up an extra space from the web page. I deleted the trailing space and Voila! I'm connected.
    Thanks for suggesting the absolute obvious. How embarassing.
  4. leejor
    11,293
    361
    No worries, it's happened to all of us.
