unable to register xlite softphone
Discussion in 'Windows' started by deepakparmar, Aug 8, 2010.
  1. deepakparmar
    Aug 8, 2010
    5
    Hi All,
    I am new user to this forum. Just installed 3CX free version on my laptop for testing.
    Also configured one extension in 3CX pabx and try to use xlite softphone.
    Xlite softphone unable to register with 3CX system, error messaage display on Xlite is
    Registration Error -404 not found.
    If anyone can guide me to fix the problem
    Deepak
  2. mazhar
    Apr 27, 2010
    10
    First check the extension status on the 3CX administration site. From where are you trying to login to the 3CX phone system? Is it from the same machine or a different one. Did you verify your firewall settings on your local PC?
  3. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,502
    68
    Usually this simply means you're trying to register as an non-existing extension. For instance, your PBX has created extensions 100, 101, 102, and you try to register as 103 - you will get "404 Not Found".
    Please check this
    Regards
    vali
  4. deepakparmar
    Aug 8, 2010
    5
    I have install Xlite on the same PC on which 3CX phone system.
    Also I creat extension 1001 with credential.
    Also firewall is disable on PC.
    but still the issue.
    Regards
    Deepak
  5. Vali_3CX
    Dec 12, 2008
    1,502
    68
    Definitely is not a problem of firewall or port. In case of such kind of misconfiguration, you will get a "408-Request Timeout" error. Also, definitely is not a problem of wrong pass, in such case you will get 403 error. I repeat, the only case is either "User name" or "Authorization user name" not matching the PBX's ones.
  6. deepakparmar
    Aug 8, 2010
    5
    In 3CX - Extension 1001
    Authentication:
    Password : 1234
    Xlite
    Authorization user name: 1001
    Password: 1234
    Domain: IP@ of 3CX system
  7. mtnman
    Sep 16, 2009
    Since you have xlite on the same machine, have you tried using localhost or 127.0.0.1 for the IP address?
  8. deepakparmar
    Aug 8, 2010
    5
    Hi all,
    Manage to fix the problem, it was SIP ID not configured properly.
    Extension - other - SIP ID
    Thanks to everyone.
    Deepak
