Unable to see or playback recordings
Discussion in 'Android' started by ddywz, Aug 22, 2013.
  1. ddywz
    Aug 16, 2013
    6
    I tried to record a conversation and the button does turn blue indicating that it is recording. I stop the recording by pressing the button again and then hung up the phone. After visiting recordings I see no records in there at all. Am I doing something wrong? Are the audio files saved in extension itself ( like the android client) or on server? I checked the PBX server too and cannot find any recordings there. Where do you define the path for such files? I do not see any config in android for this. Again this is for 3cx version 12 for android.
    Thanks,
