UNABLE TO SPA-3102 TO REGISTER
Discussion in '3CX Phone System - General' started by kunle, Sep 23, 2007.
  1. kunle
    Sep 13, 2007
    6
    I have gone through most posts regarding setting up the SPA-3102 on 3cx phone system and gone through different suggested configuration settings but I can't get the SPA-3102 to register on 3cx system.
    Line1 registers ok after putting the proxy ip address and user id, auth id and password, I can call and recieve calls from the phone connected to SPA-3102. However, the pstn line shows that registration state as failed. the Sip port is 5061.
    I would appreciate any suggestions that you may think might help.
  2. kunle
    Sep 13, 2007
    6
    My 3cx and spa-3102 config can be found below
    http://www.theojos.com/files/3cx/3cx.pdf
    http://www.theojos.com/files/3cx/line1.pdf
    http://www.theojos.com/files/3cx/pstnline.pdf
  3. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
  4. Anonymous
    Anonymous Guest
    Often you find it is a chicken and egg thing.
    try this.
    Setup 3CX first for the line id using a login and authentication, once done use the same login and authentication on the SPA
    (setup 3cx first than the spa).
    Make sure you save and reboot the spa.
  5. kunle
    Sep 13, 2007
    6
    Thanks Mirzab and Itfarmer your suggestions worked. I think where I was going wrong was not restarting the device - The device is now registered in 3cx system. Now I have to figure out dial plans - I shall be reading your other posts for further info. Once again thanks.
