Unable to start the service
Discussion in '3CX Phone System - General' started by KSRIDHAR69, Jan 3, 2012.
  1. KSRIDHAR69
    Jan 3, 2012
    System is unable to start the 3cx service. I am getting the below error message.
    The description for Event ID 0 from source PostgreSQL cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
    If the event originated on another computer, the display information had to be saved with the event.
    The following information was included with the event:
    FATAL: bogus data in lock file "postmaster.pid": ""
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    It seems to be a PostgreSQL error and there is a workaround for it.
    Try this: http://www.wavelink.com/Customer-Care-Knowledge-Base?kbid=501000000002XASAA2
  3. 12494
    12494 Member
    Apr 16, 2010
    298
    30
    Have encountered the same error.
    It would be great if you could verify the link that was posted because I am not able to access it.
    Thanks.
    Allen Miller
