Unable to use a SMTP server other than 3CX's
Discussion in '3CX Phone System - General' started by AustinM95, Mar 14, 2018.
  1. AustinM95
    Sep 16, 2017
    OS: Windows 10 Professional
    License: Standard Annual 15.5
    I'm unable to use the dropdown option to select my own SMTP server. It's grayed out. (See Picture).
    This would be fine if the 3CX SMTP server worked. When I press TEST I receive the error "AuthenticationInvalidCredentials 5.7.0 Denied"
    Need a solution ASAP!
  2. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    842
    125
  3. HRMNY
    Feb 8, 2018
    19
    Standard license does not allow for custom SMTP server. The error message is most likely a NAT issue, the source IP doesn't match that of your FQDN IP.
  4. StefanW
    Jun 2, 2009
    1,163
    74
    the issue is that the IP you are sending from is not equal to the IP which is mapped to your FQDN.
