Unblock Failed Registration
Discussion in '3CX Phone System - General' started by smepartners13, Nov 16, 2013.
  1. smepartners13
    Aug 5, 2013
    Hi.
    While testing, a particular extension/IP/MAC has been blocked for 24 hours.
    [IPBL] Packet from banned IP/range: ip = 10.0.0.106; Comment: PBX: blocked for too many failed authentications
    Is it possible to 'Unblock' this?
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
    Goto Settings >> Security >> IP Blacklist >> select the IP-Address you want to unblock, click Delete then Apply.
  3. smepartners13
    Aug 5, 2013
    Thank you, did the trick.
    Slightly confuse here because I'm switching the install between a Win7 and Win2012.
    This did not show up in the Win2012, as don't the phones, but that's a later and separate investigation!
  4. leejor
    10,374
    231
    If you continue to have issues with a particular IP, you can "whitelist" it (or a range) in the same section.
