Unconditional Call Forward
Discussion in '3CX Phone System - General' started by tjabaut, Jul 31, 2007.
  1. tjabaut
    tjabaut New Member
    Jul 24, 2007
    123
    I have been working on this problem with Rob in a previous post about transferring to another number.
    Here is what is happening. If I set through the console to Forward all Calls it works as planned; however if I use my phone (a Grandstream GXP2000) and press *72+9+1+518+542xxxx# to enable Unconditional Cal forwarding at the phone level, my phone will read call fwd enabled.
    The problem is when someone calls, it does not act like when I set Forward all Calls, instead my calls drop to VM.
    Is there any developers out there that read these boards?
    Rob and I have been working on this for about 4-5 days with no other outside assistance. In we both have Enterprise versions of this software, and I can say without support this product will go nowhere.
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    This feature (302 Moved Temporarily support) was recently implemented and hasn't been thoroughly tested yet. That is why it may not work in some cases. But we definitely ready to fix it.
    Have you ticketed your request for support?
