underscore in account number voipms
Discussion in 'Android' started by bbrannon, May 31, 2012.
  1. bbrannon
    May 31, 2012
    I'm using voip.ms as my provider. I'd like to register the 3CX droid application with a sub-account. Unfortunately voip.ms formats their sub accounts as main number followed by underscore and additional alpha numeric characters to identify the sub account. 000000_##abc It appears the 3CX does not accept the underscore. Or is the problem the alpha characters? Any simple fix on your end? Thanks
    Device Info
    Phone Model: LG Optimus VM760
    Firmware Version: 2.2.1
    Issue Info
    Handset: N/A
    Contacts: N/A
    Connection: WiFi
    Server: External chicago.voip.ms
    Also it would be nice if the forum search function would accept ". voip.ms is not searchable nor is "voip.ms"
  2. bbrannon
    May 31, 2012
    Solved my own problem. The underscore is not the problem. It was the alpha characters in the voipms sub account name/number I created. Changed it to all numeric after the _ underscore and it works just fine.
