Understanding Phonebook xml file.
Discussion in '3CX Phone System - General' started by itgs, Mar 9, 2017.
  1. itgs
    Nov 8, 2008
    54
    I know that in the provisioning folder, there are various files and, specifically, the phonebook xml files used in phones templates as remote phonebook (aastra_phonebook.xml, cisco_phonebook.xml, yealink_phonebook.xml, etc..)
    I noticed the following two files:
    3CXPhone-directory.xml
    000000000000-directory.xml
    What are the difference and what is the purpose of that files ?
    I added a new contact, using the 3CX V15 web interface, in the general phonebook and noticed that all the phonebook files was updated with the entry.
    Is it normal ?
    Last question...:
    where is the phonebook file used by the 3CX Client (windows) ?
    Thank you for support and for help me to understand
