Underwater sound
Discussion in '3CX Phone System - General' started by bdevre, Jun 26, 2007.
  1. bdevre
    Jun 21, 2007
    12
    I think I'm asking a newbie question. What do I know, I'm a newbie !
    The sound I'm getting is as if i'm under water.
    What setting could help me in that?
    Bart
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    What type of the SIP phone in-use (soft or hard phone)?
  3. bdevre
    Jun 21, 2007
    12
    Hardphone
    Grandstream GXP2000.
    Bart
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Which codec is used? (Phone shows it on the display)
  5. Anonymous
    Anonymous Guest
    Ok one out left field.
    Do you have multiple NIC's in the computer?
    What is the network traffic ?
    Funny enought and it does not sound related but if you have network issues like capacity and routing the sound starts to behave like you are in a fish tank. Do not ask me why but I had the similar problem, especially where your 3cx and your gateway have the same IP address.
    Yeah i know it is weird.
  6. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    grandstream should be fully compatible, but with my gxp2000 i had to bind that extension to the media server for the music on hold to work, maybe its not that and im dumb, but give it a try :D
