Uniden UIP 200 setup
Discussion in '3CX Phone System - General' started by miqna, Mar 10, 2008.
  1. miqna
    Mar 4, 2008
    5
    We are new to this, and liking what we see thus far, although we're having difficulty getting set up. We installed the free version of 3CX and have a number of Uniden SIP200 phones. These use TFTP to download their settings, and that is working fine, but the phone won't register with the 3CX server, it returns a "register error" on the phone and the server shows it as not registered.
    I set this extension to ID 101 and password miqna
    Here is the unidencom.txt file:
    # UIP200 Mass Configuration System Generic File
    # Notes:
    # 1. Lines start with '#' are comments, it is also possible to append a comment to the
    # end of a line by preceding the '#' with ASCII space or tab characters.
    # 2. To leave a field value unchanged (as saved on local phone), leave value to blank.
    # 3. To set a field's value to empty, use '-' as value.
    # 4. To NOT overwrite user local settings of: programmable key, one/two touch keys, VMA
    # number, VMWILampIndicator, set "OverwriteLocalSetting = NO". Default is "YES". This
    # key will ALSO affect whether or not THESE settings in uniden<MAC>.txt be used.
    # 5. Any duplicate parameters exist in both unidencom.txt and uniden<MAC>.txt, MAC settings
    # will be used.
    # MAXIMUM FILE SIZE IS 10KB
    # Current Limitation: No spaces allowed for a setting's value
    # Version: BS4.77
    #Overwrite user local settings of programmable keys, one/two touch keys, vma settings
    #If set to no, these current settings on the phone will not be overwritten.
    OverwriteLocalSettings YES # must be placed on top of config file
    # Sip Settings --If only ProxyServer needed, set OutboundProxy1/Port same as ProxyServer/Port
    ProxyServer 192.168.2.129 # can be an IP address or FDQN
    ProxyServerPort 5060 # 0 to use default port
    OutboundProxy1 192.168.2.129 # can be an IP address or FQDN
    OutboundProxy1Port 5060 # enter a port number or 0 for default (5060)
    OutboundProxy2 - # can be an IP address or FQDN
    OutboundProxy2Port 0 # enter a port number or 0 for default (5060)
    EmergencyProxy -
    EmergencyProxyPort 0
    Registrar1 192.168.2.129 # can be an IP address or FQDN
    Registrar1Port 5060 # enter a port number or 0 for default (5060)
    Registrar2 - # can be an IP address or FQDN
    Registrar2Port 0 # enter a port number or 0 for default (5060)
    RegisterExpireSec 3600
    Q_Param 50
    RegisterExpireLimitPercent 10
    Register403RetrySec 1200
    SipPort 5060
    SRVRecordName - #_sip._udp.uniden.com
    FailoverRetrySec 4 # For Redundant Outbound proxy server
    #InterDigitTimer Value in milli seconds (minimum is 1000ms = 1Second)
    InterDigitTimer 4000
    # options are ON or OFF
    SessionTimerSupport ON
    SessionTimerRefresher ON
    SessionTimerMin 60
    TimerInterval0 300
    TimerInterval1 150
    # Audio Settings
    G711MuTxPacketLength 20
    G711MuJitterBufferLength 10
    G711MuJitterBufferMax 200
    G711ATxPacketLength 20
    G711AJitterBufferLength 10
    G711AJitterBufferMax 200
    G729TxPacketLength 20
    G729JitterBufferLength 10
    G729JitterBufferMax 200
    LongHoldAlertPeriod 360
    RTPPortBase 25000
    # options are ENABLE and DISABLE
    DiffServMode ENABLE
    DefaultDiffServParam 40
    RTPDiffServParam 41
    # options are TRUNKMODE, CASCADEMODE, DISABLE
    VlanMode DISABLE
    VlanID 1
    PcVlanID 2
    #SNTP Settings
    # choices are YES and NO
    EnableSNTP yes
    # SNTP Server IP address
    SntpServerIP
    TimeZone +1 # -6 For Central Time Zone
    EnableDST YES
    # Time period (in seconds) before recontacting SNTP server
    SntpRetrySec 1800
    # preferred codec are listed from most preferred, separated by commas and NO space
    PreferredCodec g711u,g711a,g729
    # choices are English, Spanish, and French
    Language English
    #choices are Enable and Disable
    CallWaiting Enable
    EmergencyProxyPrefix **
    # STUN: If Server IP sis 0.0.0.0 STUN is disabled
    StunServerAddr 0.0.0.0 #stun.fwdnet.net
    StunServerPort 0 # 3478
    #Periodic update in seconds of MEDIA NAT ports (minimum is 10 and set 0 to disable)
    StunServerUpdateSec 0 # 30
    #Periodic update in seconds to keep SIP NAT port open (minimum is 10 and set 0 to disable)
    StunServerNATKeepAliveSec 0 # 30
    # ALLOW IP DIALING with # as the first digit map
    DirectIpDialing Enable #Enable/Disable
    # Set YES to AllowSharpAsDial to have # as your DIAL key.
    AllowSharpAsDial Yes #Yes/No
    #Flash Based Service Parameters:
    # DTMFFlashEvent (Enable/Disable) -- Send RFC2833 Event 16 when enabled and XFER button is pressed.
    DTMFFlashEvent Disable
    #HotLineDisplay (Enable/Disable) -- Do not display HOTLINE on LCD when Hotline Number is set
    HotLineDisplay Disable
    #User Agent Name Settings. Use Character "^" for space
    UseCustomizedUserAgentName No
    CustomizedUserAgentName Uniden^Customized^UA
    #Admin password must be numeric. Max is 6 digits. Format: oldpassword/newpassword
    #AdminPassword 2002/2002
    #end_of_file
    AND HERE IS THE FILE FOR THIS PHONE:
    # UIP200 Mass Configuration System Mac-based File
    # Notes: Lines start with '#' are comments, it is also possible
    # to append a comment to the end of a line by preceding the '#' with
    # ASCII space or tab characters.
    # To leave a field value unchanged (as saved on local phone), leave value to blank.
    # To disable a field, use '-' as value
    # Version: BS4.77
    # Firmware. The items listed in this Firmware section must be in this order.
    # FirmwareVersion and FirmwareFileName only used if AutoFirmwareUpdate is YES
    # FimrwareFileName only used if FirmwareVersion differ from firmware ver in Flash
    AutoFirmwareUpdate YES #choices are YES and NO
    FirmwareFileName uip200_477enc.pac
    FirmwareVersion BS4.77
    # Sip Settings
    MyLcdDisplay David
    MyDialNumber 101
    DisplayName David
    UserNameForProxy 101
    PasswordForProxy miqna
    UserNameForRegistrar 101
    PasswordForRegistrar miqna
    # Programmable Keys. Key functionality must go before key values.
    ProgrammableKey1 OneTouchDial
    ProgrammableKey2 OneTouchDial
    ProgrammableKey3 OneTouchDial
    ProgrammableKey4 CallForward
    ProgrammableKey5 TwoTouchDial
    ProgrammableKey6 DoNotDisturb
    ProgrammableKey7 VMA
    ProgrammableKey8 Mute
    # One and Two-touch keys. Must go after Programmable keys functionality definitions.
    # Refer to Programmable and Fixed Function Keys for usage guide
    # OneTouchKeyX value is used ONLY when ProgrammableKeyX is OneTouchDial
    OneTouchKey1 18005558355
    OneTouchKey2 5553456
    OneTouchKey3 3456
    OneTouchKey4 3457
    OneTouchKey5 18175553152
    OneTouchKey6 18175553152
    OneTouchKey7 18175553152
    OneTouchKey8 18175553152
    TwoTouchDigit0 3459
    TwoTouchDigit1 3450
    TwoTouchDigit2 4420
    TwoTouchDigit3 4421
    TwoTouchDigit4 4422
    TwoTouchDigit5 4423
    TwoTouchDigit6 4424
    TwoTouchDigit7 4425
    TwoTouchDigit8 4426
    TwoTouchDigit9 4427
    # Hotline and vmwi numbers --Must be placed after OneTouchDial's
    HotLineNumber -
    VmaDirectCallNo 3685 #value associating with VMA Programmable key.
    VmwiLampIndicator Enable
    TimeDisplay Enable
    ImportPhoneBook No
    #end of file
  2. miqna
    Mar 4, 2008
    5
    Too late for that, we have 16 of the phones. If we can't get 3CX to work, it will be on to another PBX. I really like this one though, and there should be no reason why it won't work.
    Since my last post, I was able to get the phone to register. Turned out that the 3CX service on the server just needed to be restarted.
    I installed a 3CX softphone and two of the Uniden UIP200 phones, and set them into a ring group. Got the line set up OK too. When calling in, only the softphone rings though.
    Any help from an admin please???
    David
